Missing cap inside the Hood
Hi, today I opened the hood and found that a cup is missing.
- Do you know for what it is?
- how does it look like? (can you post a pict)
- Where can I order a replacement?
- What liquid is inside that reservoir?
thks a lot for your help! rgrds
It is your power steering pump reservoir cap, or more corectly known as the Power Brake Booster Cap PN# 15132766. #2 below. Just google GM 15132766 https://www.google.com/search?q=GM+1...hrome&ie=UTF-8 and it will come up, its about $20.00.
If it were me, I would put some tin foil over the top with a rubber-band around the neck to hold it there until you get the cap to keep crud/moisture from falling in the pump fluid.
My bad.... I did type Brake, but I meant Power Steering Booster Cap dang nabit.
