Missing cap inside the Hood
Old May 2, 2013 | 09:31 PM
salbers's Avatar
Default Missing cap inside the Hood
Hi, today I opened the hood and found that a cup is missing.
- Do you know for what it is?
- how does it look like? (can you post a pict)
- Where can I order a replacement?
- What liquid is inside that reservoir?
thks a lot for your help! rgrds
Old May 2, 2013 | 09:39 PM
skeeter's Avatar
that looks like a power steering pump
Old May 3, 2013 | 11:35 AM
It is your power steering pump reservoir cap, or more corectly known as the Power Brake Booster Cap PN# 15132766. #2 below. Just google GM 15132766 https://www.google.com/search?q=GM+1...hrome&ie=UTF-8 and it will come up, its about $20.00.
If it were me, I would put some tin foil over the top with a rubber-band around the neck to hold it there until you get the cap to keep crud/moisture from falling in the pump fluid.
Old May 3, 2013 | 11:53 AM
happythree's Avatar
power steering cap,probably lots available at any junk yard for 2 $!!
power brakes use air pressure.
Old May 3, 2013 | 02:18 PM
My bad.... I did type Brake, but I meant Power Steering Booster Cap dang nabit.
Old May 4, 2013 | 09:16 AM
salbers's Avatar
Thks so much to all of you... good luck that i'm traveling tomorrow to USA so I just bought the replacement and should arrive durin the week
Old May 4, 2013 | 06:27 PM
groomsxxx's Avatar
Yeah mine is missing now too. Wonder why they are comming off.
Old May 4, 2013 | 08:15 PM
NJTEX's Avatar
Our old truck had 160k miles and we never lost the cap. Maybe keep an eye out on the folks who service your truck?
Old May 5, 2013 | 09:11 AM
groomsxxx's Avatar
havent had my truck long enough to need servicing. I did my first oil change and such..but the cap was on before...maybe it was just too loose.
Old May 6, 2013 | 04:19 PM
MadMarx's Avatar
Lost my cap too.
No idea how it came off.
Could it pop off?
Maybe pressure build up?
