Missing cap inside the Hood
1 Attachment(s)
Hi, today I opened the hood and found that a cup is missing.
- Do you know for what it is? - how does it look like? (can you post a pict) - Where can I order a replacement? - What liquid is inside that reservoir? thks a lot for your help! rgrds |
that looks like a power steering pump
Originally Posted by skeeter
(Post 296750)
http://parts.nalleygmc.com/images/pa...06TN06-112.JPG If it were me, I would put some tin foil over the top with a rubber-band around the neck to hold it there until you get the cap to keep crud/moisture from falling in the pump fluid. |
power steering cap,probably lots available at any junk yard for 2 $!!
power brakes use air pressure. |
(Post 296782)
Thks so much to all of you... good luck that i'm traveling tomorrow to USA so I just bought the replacement and should arrive durin the week
Yeah mine is missing now too. Wonder why they are comming off.
Our old truck had 160k miles and we never lost the cap. Maybe keep an eye out on the folks who service your truck?
havent had my truck long enough to need servicing. I did my first oil change and such..but the cap was on before...maybe it was just too loose.
Lost my cap too.
No idea how it came off. Could it pop off? Maybe pressure build up? |
