Master window switch removal
Old 10-03-2014, 09:08 AM
dyydjbb's Avatar
Default Master window switch removal
Whats the easiest way to remove the master window switch? Do you have to remove the entire door panel and then unscrew it from the back or does it simply pop out? Cant find anything in writing and dont want to break anything.
Old 10-03-2014, 09:38 AM
fp104's Avatar
pop it out at the bottom of the switch panel . use a small screw driver or plastic panel remover. it will pop up
Old 10-03-2014, 11:17 AM
dyydjbb's Avatar
Old 10-02-2015, 10:25 PM
djl1qu1d's Avatar
Used a plastic panel remover and sure enough it popped off. Unfortunately I wasn't paying enough attention and lost of the 2 metal clips (1 at each end) in the door and snapped off the little plastic nibbly bit.
But it totally worked. Does everyone's switches glow green? I didn't even know there was lights in the assembly until tonight?
I bought mine off of A1 AutoParts via eBay and stumbled on this after I popped the tabs out and removed the 3 torq screws (1 behind door lever and 2 under handle).
I am getting an RFA 1 error now for some reason. I guess it's a low battery error. doh
Hellokitty
03-31-2022 02:19 PM
Mr_Fulano
03-11-2022 11:40 AM
khanson.82
02-21-2016 06:21 PM
dyydjbb
10-31-2014 07:40 AM
heavyD
05-14-2008 04:52 PM
Quick Reply: Master window switch removal
