Master window switch removal
Whats the easiest way to remove the master window switch? Do you have to remove the entire door panel and then unscrew it from the back or does it simply pop out? Cant find anything in writing and dont want to break anything.
pop it out at the bottom of the switch panel . use a small screw driver or plastic panel remover. it will pop up
Originally Posted by fp104
(Post 317841)
But it totally worked. Does everyone's switches glow green? I didn't even know there was lights in the assembly until tonight? I bought mine off of A1 AutoParts via eBay and stumbled on this after I popped the tabs out and removed the 3 torq screws (1 behind door lever and 2 under handle). I am getting an RFA 1 error now for some reason. I guess it's a low battery error. doh |
