Loud chime
Old Aug 28, 2025 | 11:39 PM
oldguy1956's Avatar
Default Loud chime
I replaced BCM and unlocked touch screen radio now the chime in the suv is so loud it runs you out of the vehicle! I already tried to adjust the settings in config. The normal setting is louder than the loud setting! Any ideas will appreciated.
Old Aug 31, 2025 | 03:45 AM
wpage's Avatar
This may help...
Old Oct 27, 2025 | 10:58 AM
SW Washington's Avatar
I was looking to see if you have found a solution to the problem. I'm having the same issue after completing a Autel OBDII Scan on my 2009 Hummer H3 which has the touch screen radio. The door chime now blows you out of the vehicle and the radio touch screen beeps are ear piercing. I believe I induced the error when I mistakenly selected Uplevel radio instead of Navigation radio when it completed a radio setup scan. I have no idea how to correct the issue.
I've tried pulling the battery leads for 30 minutes but can not get it to go back to normal.
Thanks for any help or information you might have on getting it fixed.
Carl
Old Jan 21, 2026 | 04:25 PM
gaber6's Avatar
If aftermarket radio there is a tiny **** on the side of the adapter module to set the chime volume. I plugged mine in recently and it is louder than stock and I've been too lazy to adjust it.
FFMetal
Nov 29, 2024 06:16 PM
FFMetal
Nov 24, 2024 01:19 PM
H3steve
Jul 29, 2020 08:52 AM
Cowboy.Bebop
Jan 14, 2012 05:34 PM
jen813
Jul 24, 2006 11:00 PM
