Loose/Brocken Front Seat Side Cover
Old Aug 18, 2019 | 03:04 PM
Cohiba54's Avatar
Default Loose/Brocken Front Seat Side Cover
Got tired of the seat side cover being loose. Took the side panel and the switch panel off. Drilled 1/4” holes through both panels, replaced the switch panel, replaced side panel, inserted push rivets.
Old Aug 18, 2019 | 07:00 PM
zip ties would probably work as well. putting them through the clip loops then snapping the switch in then tighten them across the back of the switches so it pushes the switches against the panel.
Old Aug 18, 2019 | 09:30 PM
Cohiba54's Avatar
Good idea I didn’t think zip ties. You have any pics of how/where you did yours?
Old Aug 19, 2019 | 03:24 PM
no I don't have any pictures but I edited yours with yellow where I would put the straps
Old Aug 19, 2019 | 03:54 PM
Cohiba54's Avatar
Oh Ok got, seems that would work too
Old Aug 19, 2019 | 07:02 PM
Your fix is far from oem, and any ****-retentive person would see that. That's why I do all my repairs that are never noticeable. You just keep treating it like you own it, however if you decide to sell, you got some explaining to do.
Old Aug 19, 2019 | 07:19 PM
Cohiba54's Avatar
Have you had to repair you side panel?
Old Aug 19, 2019 | 08:21 PM
Yes, I have repaired many of trim panels, for my customers, mostly due to damage caused by the tech's working for me, with improper removal. I repaired, unnoticeable, and properly secured. Never a problem.
Btw, your panel looks secure!
AverageWeekend
Nov 1, 2017 08:36 PM
Wendell
Jul 3, 2017 09:16 PM
C31322
Dec 23, 2013 08:22 AM
E T H
Apr 9, 2011 10:19 PM
blackterror
Jun 21, 2009 09:03 PM
