Ok, really dumb question...how to exit H3X driver seat?
Old Dec 15, 2016 | 10:35 PM
AverageWeekend's Avatar
Default Ok, really dumb question...how to exit H3X driver seat?
Have never encountered this with a vehicle before, but here we go.....
When I get out of the vehicle from the driver side seat on my H3X, my weight pops the left side plastic seat panel loose. This is the panel that contains/covers the seat adjustment and heated seat controls. When it pops loose, it ALWAYS bumps the seat heater into the upper position (high setting). I don't always want the seat heater on! lol.
I have popped the panel back in place several times. I have analyzed how I get out of the vehicle. I just kind of roll out. I have tried spinning 90 degrees, then stepping on the nerf bars. I still pop the panel loose.
BTW, I am 6' 1" and 225 pounds.
Considering trying to remove that panel. Don't know what else to do. This is crazy. Thoughts?
Old Dec 16, 2016 | 07:20 AM
I am about the same size and frequently have the same issue. I just check to make sure the seat heater is turned off after I have sat down. Don't need it often in central Texas.
Old Dec 16, 2016 | 12:54 PM
Ordieh's Avatar
Take a sharp utility knife and carefully trim the opening in the panel above the switch. It doesn't require a lot of clearance so just trim a small amount at a time until the problem goes away. A Dremmel will work, but there is a risk of accidentally damaging the switch and it is easy to remove more material than necessary.
Old Dec 16, 2016 | 03:19 PM
Broken Halo's Avatar
There was a thread sometime back that dealt with this issue. https://www.hummerforums.com/forum/h...-just-me-5541/
It required the addition of a screw to hold the panel in place, and somebody on the forum posted a pic of the screw location but I can't find it.
Old Dec 17, 2016 | 06:54 AM
I posted the photo. I also removed the trim price and used a dremmel around the top of the opening for the seat heater switch.
I'll see if I can take a photo and post it. The dealership did the screw via a TSB from GM.
Old Dec 18, 2016 | 10:58 AM
650Hawk's Avatar
Interesting. Mine has the screw, as well, and the heater doesn't turn on when entering/exiting the vehicle. I do remember seeing something about a TSB on it. Funny, when I started looking to buy an H3, the first one I test drove cooked my butt 'cuz the seat heater was on! Now I know why!
Old Dec 19, 2016 | 01:28 PM
Found the TSB 2203598
Old Dec 19, 2016 | 01:34 PM
Thanks! If you have a copy of that TSB and/or a pic, it would be much appreciated.
Old Jan 13, 2017 | 11:57 AM
Did anybody ever get a chance to take a pic that shows where the dealer installed that extra screw on the side of the seat(s)? Thanks so much.
Old Jan 23, 2017 | 04:30 PM
Hooty-Hoo's Avatar
I ended up taking the fuse out. Accidental seat heater in July in Phx could be deadly!
