Design fault or just me?
Old May 21, 2007 | 12:03 AM
whitestick's Avatar
Default Design fault or just me?
I'm having problems with my seat heaters for the driver and passenger side front seats. It seems that whenever someone gets out, (or sometimes getting in) the seat heater switch gets toggled on. I know it's a rocker switch, but this happens so frequently that something seems amiss. Do you have a similar problem?
There are are two unused/available switch ports on the dash next to the cigarette/dc power ports, and it almost seems that they should have switches in them to control the two front seat heaters. Is this a design flaw that should have used the dash switchs rather then the ones drectly in the seats, which keep getting turned on?
Any idea of what it would cost/entail to have the seat heaters wired to switches in the dash, and disconnect the ones on the seat themselves?
Old May 21, 2007 | 06:41 AM
dilo2001gt's Avatar
Default RE: Design fault or just me?
a lot of labor
It happens to me somtimes when i get out i must hit the switch it is in a bad spot all the switches are.
Old May 21, 2007 | 10:25 AM
Hummer Guy's Avatar
It's a problem if no one is touching it, and the heater is on when the toggle switch is in the center (not engaged). It is accidental pushing if it is engaged up or down upon getting in. I haven't noticed them being bumped at all by myself or passengers...but I'm one of many thousands.
Old May 21, 2007 | 11:02 AM
Sandy07H3BG's Avatar
Happens too me all the time!
Old May 21, 2007 | 11:29 AM
Mr H3x's Avatar
I've never had it happen to me but I would suggest that you consentrate on what you are doing as you enter the Hummer and see how it is that you are flipping the switch.Maybe you can do something a little different. Changing the way you enter will be a whole lot cheaper than switching your controls around.
Old May 21, 2007 | 02:33 PM
whitestick's Avatar
Unfortunately, both my husband and myself are experiencing the same problem. And we are both too old and too sedentary to change the way we get in and out of vehicles. Never had this problem with other vehicles, not even husband's SAAB, and it has seat warmers as well - course the switches are on the dash.
Re: HummerGuy, I believe that it is a design problem rather then a mechanical problem. Don't seem to notice the other switches moving the seat out of position or anything, just the seat warmers being toggled on. Might have helped if the switch location was further back, or someplace where it doesn't get bumped as we get in and out. Thus my suggestion/question about the dash location, which seems like it was made for them anyway.
Old May 21, 2007 | 03:58 PM
Hummer Guy's Avatar
ORIGINAL: whitestick
RE: HummerGuy, I believe that it is a design problem rather then a mechanical problem. Don't seem to notice the other switches moving the seat out of position or anything, just the seat warmers being toggled on. Might have helped if the switch location was further back, or someplace where it doesn't get bumped as we get in and out. Thus my suggestion/question about the dash location, which seems like it was made for them anyway.
Anything can be done - but at some point it may be cost prohibitive.
Old May 21, 2007 | 04:14 PM
Just YOU!!
Old May 21, 2007 | 10:21 PM
whitestick's Avatar
Dang! Was afraid that might be the answer. Hoping for better though.[sm=boohoo.gif][sm=boohoo.gif]
Old May 21, 2007 | 10:36 PM
kild1's Avatar
it happens to us all the time too
