LED Taillights/ Turn Signal Speed
So could the led tail light bulbs cause an issue and blow out front turn signal fuse bc little after I changed them out to led they stopped working and every time I try to change the fuse on the front signal lights it pops the fuse rite away
You need a 12v no load flasher. It is inside under drivers side. Pull it and take it with you. I think the are two prong but I'm not sure. Universal fit depending on prong configuration. It will not affect anything else. It only determines the speed of flash. The reason the load type flash faster is so that you know when the load is not as heavy when a bulb burns out. Because leds don't pull a fraction of amperage your current flasher thinks a bulb is burnt out.
GrampaEJ
Jan 10, 2019 09:45 AM
rob07002
Feb 3, 2017 11:43 PM
bobh002
Sep 6, 2007 06:59 PM
