intermittent starting problems
Old Oct 22, 2019 | 11:23 AM
mjkostas's Avatar
Default intermittent starting problems
Complete new engine rebuild. Intermittent engine starting problems. after driving over 30 minutes and turn off, it acts like dead battery for 15 minutes or more then starts right up.
new starter relay didnt help
Old Oct 22, 2019 | 11:47 AM
sounds like heat is affecting something. you might have to double check that your harness connectors are properly seated and that all grounds are connected and tight. check your battery terminals as well they might need tightening or replacement.
Old Oct 22, 2019 | 12:36 PM
PASSLOCK, check to see if there is a little red lock symbol on your dash when you are unable to start it.
Old Oct 22, 2019 | 02:48 PM
MOVED this from the H3 FAQ section where it tells EVERYBODY "Do not post in this section." Just because you thought up some question does NOT make it an FAQ.
All H3 questions belong in the................................ H3 Section.
Welcome to HF.
Peepsdada
Oct 31, 2019 12:39 PM
hummer_on_fumes
Oct 11, 2019 11:39 AM
Kayala1
Nov 5, 2017 10:39 AM
jens
Jan 27, 2015 02:53 PM
samijane
Apr 21, 2014 10:21 AM
