Intermittent ABS/Traction lights
Old 11-21-2017, 09:55 PM
Chimpy's Avatar
Default Intermittent ABS/Traction lights
2006 H3 Base. I have searched for this particular problem but only found situations where the lights stay lit. I have had the ABS/Traction lights coming on then go off while driving. Sometimes after the lights have gone off, the brakes seem to grab at a stop and there is a click sound that I also feel in the brake pedal. Sometimes the brakes will feel normal coming to a stop. Randomly the lights may come back on again, then go back off and the cycle will continue. No loss of power during all of this though. I still have the stock battery terminals but had the battery replaced a few weeks ago. The Hummer seems to start fine although I do notice when the click sound/feel at the brake pedal happens when coming to a stop, the headlights might briefly dim then come back up.
Old 11-22-2017, 07:45 AM
I would see if a code reader could capture the fault codes.
Did this issue start right after the battery swap? Possible that an ABS wire is loose or going bad too.
Old 11-26-2017, 02:59 PM
Chimpy's Avatar
Finally was able to check the code and the front left sensor is the culprit. That bearing also happens to be showing some slight play so I will kill two birds with one stone.
hollywood_x
18
07-11-2017 09:44 PM
Wfive
04-08-2016 01:45 PM
mnorrick1
04-05-2016 06:57 AM
rifsm1
08-21-2012 02:10 PM
BOSS1705
10-16-2008 11:22 PM
Quick Reply: Intermittent ABS/Traction lights
