Interior Overhead and Floor lights not working
Old Aug 13, 2025 | 06:19 PM
RKTonyC's Avatar
Checked out the visor vanity light circuits, and both are good. Used the oem bulbs, and circuit tests showed them active.
I reinstalled them, but everything that was previously not working are still out. On to the next I guess.
Old Aug 14, 2025 | 11:26 AM
Disconnecting the Battery does not reset anything, it just causes a reboot so that it MIGHT clear a glitch. Your H3 PCM stores the last 300 ignition cycles power or no power.
You likely have a BCM and or BCM harness issue.
Old Oct 9, 2025 | 05:58 PM
RKTonyC's Avatar
Update: So today I decided to replace my plugs, coils and clean the throttle body. I had a misfire on cylinder 1, which always cleared up after driving awhile. But since it has almost 155k, figured it was due. Runs awesome now.
So, I decided to take out the BCM and give it a little internal cleaning, and decided to just replace fuse #56 with a new one. Lo and behold, interior lights, and turn signals are all working perfectly again.
It was a good day!
Old Oct 10, 2025 | 09:18 AM
Thank you for following up on your success, it really helps others ID the problem and points to a fix.
H3steve
Aug 13, 2020 09:56 AM
Mambachee
Mar 23, 2019 10:57 AM
poway14
Jun 14, 2015 03:43 PM
Porschepowered
Dec 3, 2013 03:48 AM
HummerH2
Jul 16, 2011 01:47 PM
