2009 H3 3.7L – Temp Gauge Works Cold But Dies Later + ABS Codes
Old Sep 30, 2025 | 03:50 PM
kyleklinski24's Avatar
Default 2009 H3 3.7L – Temp Gauge Works Cold But Dies Later + ABS Codes
Thread Title: 2009 H3 3.7L – Temp Gauge Works Cold But Dies Later + ABS Codes
Post:
Hey guys, looking for some advice on my ’09 Hummer H3 (3.7L I5).
I recently replaced the coolant thermostat because I was getting a P0128 code (engine not reaching proper operating temp). After the replacement, things seemed better — when I start it cold in the morning, the engine temperature gauge reads accurately and climbs like normal.
Here’s the weird part: later in the day, after driving or restarting, the gauge stops working. It’ll sit dead, like it’s not getting a signal anymore. Almost as if the sensor or gauge drops out after warming up.
I already replaced the coolant temp sensor (ACDelco, so OEM quality), and it worked fine for a few days, but then the issues came back. Coolant level is good, system was burped, and I just installed the new thermostat.
On top of that, I’m also chasing some ABS codes:
  • C0268 – ABS Pump Motor Circuit Open/Shorted
  • C0244 – PCM Indicated Reduced Engine Torque
  • C0710 – Steering Wheel Position Sensor Circuit
  • C0899 – Device Voltage Low
  • U1000 – Class 2 Communication Malfunction
From what I’ve read:
  • P0128 + gauge issues → thermostat or wiring/sensor problem.
  • C0268 seems like the main ABS fault (pump motor circuit).
  • The other C-codes and U1000 might be related to low voltage or grounding problems.
Battery and alternator seem okay on a quick check, but I haven’t load tested them yet.
Has anyone seen the temp gauge cut out after warm-up like this? Could it be a wiring issue to the cluster/ECM instead of the thermostat or sensor? And for the ABS — should I chase the pump motor circuit first before worrying about the steering sensor and comm codes?
Any input or similar experiences would be appreciated.
Thanks,
Kyle
Old Sep 30, 2025 | 10:53 PM
Happy Hummer's Avatar
I would start here. If the comm isn't talking nothing is going to work.
Clear all codes . Then rerun codes again. If comm code comes back make straight to the dlc. Check to make certain you have ground and positive. That the Class 2 is working properly with a good oscilloscope. You should see 120ohms across the network using a dvm set to ohms. If not start breaking the network into sub parts. jmho
Old Sep 30, 2025 | 10:54 PM
Lol by the way that's all I got.
Old Oct 2, 2025 | 09:14 PM
gaber6's Avatar
Batteries do funky things before they die. Easy free test at the store. I had a 4runner that would flicker all the gauges and lights and I chased other ideas until realizing it was just the battery.
Old Oct 3, 2025 | 09:06 AM
OK, let's beat the dead horse Battery Terminal Connectors..... Are you still trying to use the crappy azzed OEM Battery Terminal Connectors? If so, hack them off and replace with a quality aftermarket set, like Stingers or your favorite brand. THE #! MOD to do to every H3/H3T. Know defective parts leading to all kinds of electrical Gremlins.
Old Oct 10, 2025 | 07:29 PM
BlueH3's Avatar
My 2009 also does this when really cold always in the 20’s in winter - never in warmer temps. Warms up, gauge works for a while, then cuts out and AC OFF code comes on - wierd! Next start up is fine depending on outside temp.
JerseyCoast
Aug 18, 2025 09:47 AM
ojh32008
Dec 23, 2024 11:42 AM
lilcmtz
Jul 17, 2020 01:18 PM
Hummerforever
Mar 4, 2019 08:22 PM
Jeff Bartnett
Aug 17, 2016 09:06 AM
