Info on were to find part
Old Apr 4, 2019 | 12:34 PM
Redtail's Avatar
Default Info on were to find part
Hi folks new here. I have a H3 that has a vent line leak coming from the charcoal canister. It was smoke tested and the leak is behind the tank on the metal line. The shop told me they would have to drop the tank. I dont think so thinking outside the box i want to pull a new line for the CC to the engine..Question is were can i buy the hose to do the job or does anyone know what the ID of that hose is . Needs to go from the CC to the engine...thank you in advance....
Old Apr 4, 2019 | 12:38 PM
Redtail's Avatar
Hi folks new here. I have a H3 that has a vent line leak coming from the charcoal canister. It was smoke tested and the leak is behind the tank on the metal line. The shop told me they would have to drop the tank. I dont think so thinking outside the box i want to pull a new line for the CC to the engine..Question is were can i buy the hose to do the job or does anyone know what the ID of that hose is . Needs to go from the CC to the engine...thank you in advance....In the pic is item 14
Old Apr 4, 2019 | 01:59 PM
Happy Hummer's Avatar
Do you know the exact location of the EVAP leak in the line?
I used EVAP grade fuel grade hose and small clamps to fix one in the past. Just cut out the bad section and run the appropriate grade and size. Some decent zip ties done.
Old Apr 4, 2019 | 02:48 PM
Redtail's Avatar
Happy the smoke leak is right in the middle of the tank and frame..that is why i am going to just run a whole new line.just trying to find a company that sells the tubing..called the auto parts stores they were clueless...trying to find out the size of the line i need..THANKS
Old Apr 4, 2019 | 02:52 PM
You can buy the entire line #14, it's ACDelco.
Otherwise use 3/8" or 10MM rubber fuel hose run it from the CC to first place you can access in front of the fuel tank.
I have also fixed old car EVAP leaks w/3/8" brake line and compression fittings. All simple stuff.
Old Apr 4, 2019 | 03:06 PM
Redtail's Avatar
Doc thanks for the info...
Old Apr 4, 2019 | 03:14 PM
Redtail's Avatar
Doc question is that 3/8 OD or ID..THANKS
Old Apr 4, 2019 | 03:54 PM
Let me know when you find a 3/8" OD.
lex
Mar 18, 2020 08:58 AM
myrddin
19
Jul 10, 2019 04:18 AM
mulepic
Oct 24, 2015 09:05 AM
KruBruder
Feb 22, 2012 07:35 PM
dwd58
May 25, 2010 05:01 PM
