I have a 2006 Hummer H3 and The driver’s door mirror; how do I tighten it?
Old Sep 1, 2019 | 10:05 PM
ChiefUSN's Avatar
Default I have a 2006 Hummer H3 and The driver’s door mirror; how do I tighten it?
My 2006 Hummer H3 has a loose driver’s door mirror. How do I tighten it?
Old Sep 2, 2019 | 06:49 AM
Ordieh's Avatar
Assuming you are referring to looseness between the base and the mirror frame......... Pick up some 2 inch industrial strength VELCRO. Cut a strip of the “softer” hook material long enough to allow a good grip of the ends with both hands. Peel the backing and force the strip as far as possible between the base and the mirror frame. Carefully trim the excess with a razor blade. All of the mirrors on both of my H3’s were loose. I did this years ago and they are still nice and firm. Good luck!
Old Sep 2, 2019 | 07:42 AM
ChiefUSN's Avatar
Default Loose H3 mirror
I would have never thought of that for a solution. If I can’t tighten up a bolt I might try it. Thanks
JBROEREN
31
May 16, 2016 01:05 PM
hunter8793
Jun 22, 2014 11:40 AM
justanotherhemi
Jan 31, 2012 04:27 AM
PeterM
Aug 7, 2011 06:55 PM
shaunskie
Sep 19, 2007 08:11 PM
