Hummer Stalls during hot days :(
Old Jun 25, 2012 | 02:36 AM
2008h3denver's Avatar
Default Hummer Stalls during hot days :(
Hi Everyone,
I am seeking help everywhere I can now, I bought my hummer about 2 years ago and never had any issues until now, the engine dies constantly and that has become a nightmare. Hummer usually runs good until we stop at a street light and try to regain speed, sometimes it even dies when we are driving at low speeds. The symptoms that I have noticed are:
-ngine runs hotter than normal, usually the needle is above the middle during hotter days and it fluctuates back and forth.
-When the engine dies it usually starts again after 1 or 2 min.
-Once it re-starts "check engine" light comes on, and it disappears once we get home and stop the car.
-Mechanics haven't found any codes.
-So far I have replaced the spark plugs, cleaned the air intake, throtle body, changed one ignition coil and changed the thermostat and our friend keeps
acting up
I wonder if any of you guys have any suggestions? is it possible that the fan clutch or the water pump may be causing this problem?
Any answers will be greatly appreciated.
Old Jun 25, 2012 | 07:40 AM
jrv435's Avatar
I had a similar problem with another truck I had and found that the fuel injection pump relay was bad. It would stall at lights and low speeds and it won't show a code during diagnostics. Good luck...Hope this helps...
Old Jun 25, 2012 | 01:58 PM
Thanks JRV, I will check that today to see if it helps.
Old Jun 30, 2012 | 07:32 PM
No, it didn't work. The relay was good. perhaps it would help if I clean the radiator?
Old Dec 29, 2022 | 06:24 AM
AussieH3Hummer's Avatar
Originally Posted by 2008h3denver
Hi Everyone,
acting up
Hey 2008h3denver
Did you ever find a solution to this problem? I have had the same issue exactly as you described, the last 2 summers. TIA
Old Dec 29, 2022 | 09:05 AM
Originally Posted by AussieH3Hummer
Hey 2008h3denver
Oh Boy......... a resurrected TEN YEAR OLD THREAD!!!!!!!!!! There is an award to be given for that one.
NO he did not, and if they did, we will NEVER KNOW as 2008h3denver's Last Activity was: 07-18-2012 05:10 AM
READ: Old Threads/'Necro-Bumping'
Do not dig up old threads, post a NEW Thread including year, model, miles, symptoms, scanned codes, and a description of any work done just before the problems started, if applicable.
mjtermini
Jun 24, 2012 10:24 AM
HummerGuy
Feb 4, 2008 06:44 AM
