Hummer H3 Radio - Intermittent in cold weather
Old Jan 12, 2021 | 02:11 PM
Sergiog1's Avatar
Doc Olds, I'm not sure what type of feedback you expect? I'm telling you that the theory the speakers are bad is not the problem. ALL....ALL the speakers are off and then all of a sudden, I hear a click and them all the speakers work. How much more do you need? Really...???
Its unfortunate your theory is not the problem. I wish it was, because it would be the simplest to solve. But it isn't...!!! You're well come to continue to suggest suctions and I will vet them out, but if you want me to agree with you flat out.... don't waste your time or mine...!!!
Old Jan 12, 2021 | 02:13 PM
Sergiog1's Avatar
Hi Bronxteck, I think your suggestion sounds very possible. The problem is how do I find that relay...???? If I knew where it was I would change it immediately to try and see if that was the issue. If you learn of anything else, please advise.
Thank you,
Sergio
Old Jan 12, 2021 | 02:34 PM
Thank you,
Sergio
In your owners manual, or you can look here: Hummer H3 / H3T (2005-2010) fuses and relays
Old Jan 13, 2021 | 07:51 AM
brothapig's Avatar
Do you have the Monsoon radio system? There is an external amplifier on the rear left wheel well. It gets a "radio on" signal, which I presume would enable the amplifier. Maybe you have an intermittent connection there.
Sergio Gustavo Burgos Romano
May 14, 2019 04:38 PM
ceds
Jun 22, 2012 06:51 AM
attila787
May 18, 2007 10:13 AM
Ken06H3
May 17, 2007 10:14 PM
fatdog77
Jul 17, 2006 06:43 PM
