Howling sound from transfer case
Old Aug 20, 2020 | 01:39 PM
LatvjuAvs's Avatar
Aye, will polish shaft and take little bit of extra, then will use new sleeve with rollers.
This has happened because I was driving with 4HI locked, even indicator showed that I was in 4HI unlocked.
As load on this is only when turning with 4HI locked.
I had plastic fork changed to metal, half a year ago, then this shaft was healthy.
Will have to figure out how to diagnose 4Hi locked-unlocked state.
As I click buttons, state changes.
I remember when I clicked 4HI from 4HI locked there was no sound, but indicator changed anyway.
Maybe encoder motor problem. No codes about it though.
Old Aug 21, 2020 | 11:14 PM
Eurynomestolas's Avatar
how long were you driving in 4 hi 🔒 for this to happen? I mean you couldn’t tell the back wheels were grabbing?
Old Aug 22, 2020 | 06:08 AM
LatvjuAvs's Avatar
That is the weirdest thing, I did not felt/heard back wheels grabbing more than few instances.
There was some instances where I was backing up with HI locked, unlocked, moved forward and had wheels skipping, then it stopped.
Anyway, shaft is polished, everything is being put together, some bearings needed change, input bearing had a play, will fix it up and see how it goes.
Will keep eye on wheels.
Old Aug 22, 2020 | 02:12 PM
if too much was removed when polishing you might need a little thicker sleeve to make up the difference that was lost to polishing
bigstick0000
Sep 17, 2020 09:29 PM
man-of-war
Nov 5, 2013 06:22 PM
Ahmad
Jan 17, 2013 07:40 PM
Wayne Auto Ebay
Nov 12, 2012 02:09 PM
K0PIR
Feb 14, 2012 11:32 AM
