How To Remove Dash Panel Below Steering Column
I'd like to connect a brake controller to the factory installed trailer brake control wiring under the dash in my 08 H3. I can see the wiring exactly where the owners manual says (to the right of the steering column attached to the courtesy light). However, I can't readily get to it.
Can anyone advise how to remove the dash panel located below the steering wheel to gain access to the trailer harness wiring connections?
Thanks in advance for any feedback.
The knee bolster?
4 clips hold it in, remove outer panel, remove hood release handle screws, parking brake handle and pry/pull outward.
All instructions found here:
http://www.automx.co.za/htdocs/manua...rm_2008119.pdf
HUMMER Forums has memberships? Do you get a free bowl of soup with that membership?Outer panel:
side dash cover(#29 pull that off), 1 bolt behind the side cover (#23), 2 screws holding the hood release, remove parking brake release pull, spin the parking brake release cable until it pops out of the corresponding holes. pull the Outer panel #22 toward the driver seat (4 clips).
Inner structure
6 bolts #1, 2 screws holding the hood release, 1 clip for the OBDII plug.
BCM for every H3/H3T behind the passenger side interior kick panel.
quadblaster240
Mar 30, 2012 07:48 PM
Hummer2006h3
May 30, 2011 02:01 PM
patricktheelder
Jul 4, 2010 05:46 PM
