How to Disable Beeping in the Hummer?
Old Dec 27, 2008 | 08:26 PM
gkhogg's Avatar
Default How to Disable Beeping in the Hummer?
Anyone know of how to disable the beeping the Hummer makes when the key is left in the ignition and the door is open??
Sometimes your just hanging out and the doors are open and your still using the sterio, but the damn thing keeps beeping and it drives me nuts. Anyone know how to disable it? Or make it so it beeps for 5 seconds when you first open the door, then turns off for good?
Old May 30, 2022 | 04:23 PM
Pipper's Avatar
Default Solved Bleeping beeping
Bleeping beeping!! Ugh!
I solved the same issue by:
Looking where vin info is and just to side on the flat part between front and passenger door on the driver's side, there is a black 3 inch piece of rubber that you can pull on to remove. Once the cover is off I see a white push button. I wiggled that and slid it upward. It is just a plastic clamp type deal. Came right out with a spring. So I will baggy up and keep if needed later. At camp with radio going during setup, NO DINGY DINGY!! I WOULD SET A PHONE ALARM TO START VEHICLE TO CHARGE EVERY SO OFTEN. CHEERS!
Old May 30, 2022 | 08:30 PM
simpler solution it to open the windows and close the door.
Old May 31, 2022 | 02:46 PM
gpcalero's Avatar
Pipper, you responded to a question that was asked 14 years ago.
I don't think he may need the answer any longer lol. You should've just made a post about the subject on your own.
Old May 31, 2022 | 03:59 PM
"3 inch"?
The ignition key "Dinging" is triggered by the DDS (driver door switch)!
I use my stereo all the time on job sites:
1- Open driver door window
2- Get out and close driver door(or clamp the door switch)
3- Open passenger door insert ignition key to the ACC (accessory) position.
4- Open all doors (including the cargo door H3) except the driver door.
5- Monitor voltage
Big_Joke
Jul 22, 2020 11:12 PM
pauly1052
Jun 27, 2015 04:51 PM
Humvee21
Apr 10, 2015 03:28 PM
Nate2106
Feb 8, 2014 06:31 PM
johnmully
Sep 14, 2013 11:51 AM
