removed aftermarket car immobilizer
Old Jun 1, 2022 | 07:50 AM
upnorth's Avatar
Default removed aftermarket car immobilizer
Brought my 07 to get this removed and now seems a few things happened. Shows my door is opened, stereo shuts down when I take the key out and seems I cant set the trip odometer back to zero. Guess the guy has some wires hooked up wrong ? Have to bring it back in to check it out, any ideas ?
Old Jun 1, 2022 | 10:37 AM
the door and the radio are related.
the security system probably used the door switch to trigger an entry. probably just need to check the switch and it's wiring.
normal operation of the radio is once you remove the key and you open the door then it shuts off.
Old Jun 1, 2022 | 12:45 PM
Your 07 WHAT? Infor for the models goes in the model's designated section............. ie. all H3 stuff goes in the H3 section. Crazy like that.
This General Hummer Talk was for generic non-model specific Hummer info.......... most of which is now moot because there is no Hummer manufacturing.
Old Jun 1, 2022 | 04:52 PM
upnorth's Avatar
07 h3 sorry, says "General Hummer Talk"
Old Jun 1, 2022 | 04:58 PM
upnorth's Avatar
Thanks, it worked alright before I had this imobilizer removed, so must be how he wired it right ? also the trip odometer doesnt seem to want to set back to zero, can this be related also ? Thanks in advance.
Old Jun 1, 2022 | 05:37 PM
the trip odometer issue is most likely the reset button not being used regularly. try pushing it a lot maybe it will clear the contacts in the button.
Old Jun 1, 2022 | 05:44 PM
Post a pic of the repair, wires crossed? There are many different colored wires, restoring back to oem is simple. Match the solid colors & colors with tracers(striped 2 color wires), can't mix and match.
jsbihn
Apr 7, 2019 06:30 PM
Chi-town81
31
Jan 10, 2014 11:51 AM
CGENERAL
Apr 10, 2008 03:14 PM
