How to detach plug
Old Oct 20, 2022 | 02:33 PM
surfcityred327's Avatar
Default Hummer h3 cooling water sender help
I am attempting to change my water temp sending unit. However, I can't get this clip in the sender wire to release the end of the old sender wire. I have screwed around for hours. Here is a photo of the thing I can't unclip. It's the end of the plug with the protective tubing on it in the foreground. HELP!
Old Oct 20, 2022 | 02:44 PM
Default How to detach plug
I have a 2008 Hummer H3 and I am trying to change out the water temperature sending unit. My problem is I can't figure out how to remove the old plug from the socket it is in. I have tried for hours and I can't figure the dang thing out. The photo shows the plug and I am trying to remove the plug in the foreground, that has smooth black tubing on it. HELP!
Old Oct 20, 2022 | 03:00 PM
You are focusing trying to disconnect the wrong end. Push down on the visible tab (in the center where you ripped off the covering) and disconnect the electrical harness connector. Remove sensor and smooth black loom over it with the sensor.
Google and watch the vids
Old Oct 20, 2022 | 03:19 PM
Release the lock tab 1st!
Old Oct 20, 2022 | 03:59 PM
Old Oct 21, 2022 | 07:19 AM
Remove the grey safety (don't lose it!!!) then press the black clip down like normal.
Old Oct 21, 2022 | 07:20 AM
Remove the grey safety lock thingy (don't lose it!!!) then press the black clip down like normal.
Justinh
Dec 23, 2020 08:20 AM
Broken Halo
Nov 8, 2020 01:20 PM
H2Miami
Nov 3, 2011 06:45 PM
luda81
Dec 22, 2010 05:02 PM
josh1899
Mar 22, 2008 10:52 AM
