Help! Installing new stereo for son's birthday!
Old Aug 16, 2020 | 03:50 PM
bassackwards's Avatar
Default Help! Installing new stereo for son's birthday!
And it is not going well at all.
Alpine ILX-650 head unit with Access AX-GMCL2 interface.
We have everything working but the parking brake circuit. I checked my connections and they are right.
Crutchfield was not much help.
Which wire is feeding the factory stereo plug from the parking brake?
Old Aug 16, 2020 | 06:07 PM
most of the time you can just ground the radio parking brake wire. then it always works no need to put the brake to watch things.
Old Aug 16, 2020 | 06:20 PM
On this one the parking brake has to be set-released-set again before it will allow you to access the setup mode.
Old Aug 16, 2020 | 07:45 PM
If you tap the thingamagiggy that came with the kit it goes into the settings mode.... or it looses all power.
I think we have a defective thingamagiggy
Old Aug 16, 2020 | 08:20 PM
put a switch you can toggle then to ground
Old Aug 17, 2020 | 10:51 AM
OK, just did this with 3 Alpine ILX-650 head units. 1 for each of our vehicles (2 H3Ts and The EXCURSION). It is a pain to depress the pedal then release then depress again in the allotted time Alpine gives you.
1. Do yourself a favor and get the Alpine Micro bypass. Buy this exact one!
2. Then watch the video link. you ONLY need to connect 3 wires for the ILX-650 (new style).
PRODUCT:
https://www.amazon.com/gp/product/B006FKAHFM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B006FKAHFM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
VIDEO:
This way you can adjust the tone settings and other things while moving too.
Old Aug 19, 2020 | 02:52 PM
PRODUCT: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
VIDEO: https://www.youtube.com/watch?v=fxkvUNdDhiM
Taint, what radio adapter did you use for the H3T installs?
Old Aug 20, 2020 | 08:19 PM
We replaced the little black box and it is all working correctly now
Old Aug 20, 2020 | 08:20 PM
Still can't watch dvds without stopping and setting the brake but at 16 and getting his license tomorrow I am good with that
Old Aug 21, 2020 | 05:26 AM
With Monsoon I use Crux SOCGM-17C -
Amazon Amazon
Simple install with the new solder seal wire connectors. I use them on everything 12V now.
https://www.amazon.com/250PCS-Solder-Seal-Wire-Connectors/dp/B07N2HMSKD/ref=sr_1_8?dchild=1&keywords=solder+barrel&qid=1598005311&sr=8-8 https://www.amazon.com/250PCS-Solder-Seal-Wire-Connectors/dp/B07N2HMSKD/ref=sr_1_8?dchild=1&keywords=solder+barrel&qid=1598005311&sr=8-8
