Help! Installing new stereo for son's birthday!
Old Aug 21, 2020 | 07:38 PM
those crimps are not good for really hot locations. they use a low melting point solder and they really don't have enough solder to really wet the larger wires.
Old Aug 22, 2020 | 03:51 PM
bassackwards's Avatar
We already paid for the adapter that Cruchfield packages for Hummers so that is what we went with. It seems to be working correctly with the replacement black box.
Old Aug 23, 2020 | 04:54 PM
searay93's Avatar
I'm also having a similar issue my Alpine ILX-650 in regard to the park brake wire. I wired it up correctly, but I am unable to access the Alpine's settings with the park brake set. I'm using the same Axxess interface from Crutchfield. Did you contact Crutchfield and they sent you a new "box thing" for free?
Old Aug 23, 2020 | 06:29 PM
Yes and they sent us a new one. It works now. The old one would only chime about 2x before going silent and the replacement will go all day if you can stand it.
Old Aug 23, 2020 | 07:19 PM
searay93's Avatar
Alrighty, thanks. Did your initial one have any other issues other than the park brake issue? Mine is all up and working fine but the only issue is I can’t access my Alpine’s settings even though the car has park brake on. I triple checked and my park brake is properly wired through my black box.
Old Aug 23, 2020 | 07:32 PM
Where did you get your park brake?
Old Aug 23, 2020 | 09:07 PM
searay93's Avatar
By park brake I am referring to the wire connection for the park brake circuit that goes through my GMOS box to my Alpine head unit
Old Aug 24, 2020 | 08:45 AM
Our chime did not work correctly either.
Old Aug 24, 2020 | 06:08 PM
How about speakers? We are looking at the $45 Rockford Fosgates from Crutchfield. Any reason why we should not go with these?
Which size? 6.5 or 6.75? It looks like both will fit with the adapters that Crutchfield throws in.
Old Aug 25, 2020 | 11:12 AM
Either will fit, and you do not need any adapters. I put P1650 6.5" 2 ways in the front doors, and P1675 6.75" 3 ways in the back doors using XTC Baffles with the bottoms cut out for moisture protection, after Dynamat Extreme to the bottom 12" of the outer door skins, and some to the inner skins. I am very pleased with the upgrade over the OEM speakers, HUGE! Not talking about volume, but sound quality.
Still using my OEM 6 disc changer until I score an Alpine ILX-W650 deal and have time to play with it, ..... hence my interest in this thread.
Question, did you need any head unit surround to tightly fit the factory opening?
