Help: Ignition stays on, no crank
Old Aug 24, 2025 | 07:19 PM
Cinco's Avatar
Default Help: Ignition stays on, no crank
Need help: 07 H3
Battery went dead the other day. I charged it and now the ‘P’ stays on, radio stays on, and chime is dinging. Even with the key out the ignition. Have to disconnect battery to prevent draining
-ON position works
-Key turns to START but will not crank.
-I installed a new ignition switch today. Same thing.
-Passlock was deleted last year by BCM programming.
Old Aug 24, 2025 | 07:57 PM
Scan ALL modules then post the codes.
Old Aug 24, 2025 | 08:00 PM
Cinco's Avatar
Disconnected the (recharged) battery for 30s. Reconnected and boom. Started right up.
I can’t believe this.
Will scan for codes. Thanks.
Old Aug 24, 2025 | 08:16 PM
Cinco's Avatar
Any thoughts on these, when I just replaced both cam sensors and crank sensor
Old Aug 25, 2025 | 06:46 PM
Hummer H3 codes P0340 and P0341 both point to issues with the Camshaft Position (CMP) Sensor "A" circuit. P0340 indicates a general circuit malfunction, while P0341 signifies a range or performance problem. Common causes include a faulty CMP sensor, wiring issues, a loose or damaged electrical connector, or, less commonly, a problem with the engine's timing components.
This video explains how to fix the P0341 engine code:
Potential Symptoms
You might experience symptoms like:
  • Hard starting or intermittent starting
  • An engine that idles too low or too high, or has a "rolling" or "surging" idle
  • Misfires or a rough-running engine
  • Loss of engine power
  • The engine stalling
Possible Causes & Solutions
  1. 1. Faulty Camshaft Position (CMP) Sensor:
    The sensor itself can be damaged or dirty, leading to incorrect readings.
  • Solution: Remove and inspect the sensor. Clean any dirt, metal shavings, or sludge with a clean cloth to improve its signal.
  • 2. Wiring and Connector Problems:
    Loose or broken wires and damaged electrical connectors can cause a circuit malfunction.
  • Solution: Carefully inspect the wiring and connector for the CMP sensor for any damage or corrosion. Try pushing the connector together to ensure a secure connection.
  • 3. Timing System Issues:
    Although less common, problems with the timing chain, belt, or tensioner could cause the camshaft timing to be off, triggering the sensor codes.
  • Solution: If the sensor and wiring checks don't resolve the issue, a mechanic should inspect the engine's timing components to ensure they are correctly synchronized.
  1.
Next Steps
  1. Inspect the CMP Sensor: Check for any obvious damage or contamination to the sensor.
  • Check Wiring and Connectors: Ensure the electrical connection to the sensor is secure and the wiring is intact.
  • Diagnose Engine Timing: If the above steps don't work, the vehicle may need a professional inspection of its timing components.
Old Aug 26, 2025 | 01:17 AM
Happy Hummer's Avatar
Clear all codes and see which come back. Then your have relevant data.
Old Aug 26, 2025 | 08:51 AM
Are you still trying to use the Crappy Azzed OEM Battery Terminal Connectors?????? If so, big mistake. First mod to be done to every H3/H3T is to hack the OEM Terminal Connectors off and replace with a quality aftermarket set like Stingers or your favorite brand.
Old Aug 29, 2025 | 03:57 AM
wpage's Avatar
"><img src=" /> ">Stinger SPT53102 PRO Classic Battery Terminal with 8 Outputs Shoc-Krome
Stinger SPT53102 PRO Classic Battery Terminal with 8 Outputs Shoc-Krome Stinger SPT53102 PRO Classic Battery Terminal with 8 Outputs Shoc-Krome
4.44.4 out of 5 stars
(33) (33)
Price, product page
$29.99"><span style=$29.99" /> $29.99">$29.99
$7 delivery Tue, Sep 2
Only 9 left in stock - order soon.Add to cart
More Buying Choices
$25.00
(3 used & new offers) (3 used & new offers)
"><img src=" /> ">Stinger SPT55308 PRO Series Classic Short GM Battery Post Shoc-Krome
Stinger SPT55308 PRO Series Classic Short GM Battery Post Shoc-Krome Stinger SPT55308 PRO Series Classic Short GM Battery Post Shoc-Krome
4.64.6 out of 5 stars
(89) (89)
Price, product page
$9.99"><span style=$9.99" /> $9.99">$9.99
FREE delivery Mon, Sep 1
Only 13 left in stock - order soon.Add to cart
More Buying Choices
$9.75
(17 new offers) (17 new offers)
"><img src=" /> ">Stinger SHT301 HPM Series Digital Battery Terminal with 1/0 or 4 Gauge Outputs and Digital Volt Meter (Positive Only) silver
Stinger SHT301 HPM Series Digital Battery Terminal with 1/0 or 4 Gauge Outputs and Digital Volt Meter (Positive Only) silver Stinger SHT301 HPM Series Digital Battery Terminal with 1/0 or 4 Gauge Outputs and Digital Volt Meter (Positive Only) silver
(55) (55)
Price, product page
$56.99"><span style=$56.99" /> $56.99">$56.99
Only 4 left in stock - order soon.Add to cart
Best Seller
"><img src=" /> ">SINGARO Car Battery Terminal Connector, 4 Way Positive and Negative Pole Quick Release Terminal Clip, Applicable to SAE/JI...
SINGARO Car Battery Terminal Connector, 4 Way Positive and Negative Pole Quick Release Terminal Clip, Applicable to SAE/JIS A Type Terminal Post, Compatible with Cars, Trucks and More(Gold-A) SINGARO Car Battery Terminal Connector, 4 Way Positive and Negative Pole Quick Release Terminal Clip, Applicable to SAE/JIS A Type Terminal Post, Compatible with Cars, Trucks and More(Gold-A)
4.54.5 out of 5 stars
(3.9K) (3.9K)
3K+ bought in past month
Price, product page
$6.99 List: $12.99"><span style=$6.99 List: $12.99" /> $6.99 List: $12.99">$6.99 List: $12.99
List: $12.99"><span style=List: $12.99" /> List: $12.99">List: $12.99
Today
FREE delivery Today 5 PM - 10 PM on $25 of qualifying itemsAdd to cart
<u>+3 other colors/patterns</u> +3 other colors/patterns
"><img src=" /> ">Stinger SHT303 HPM Series Battery Terminal with Two 1/0 or 4 Gauge Outputs
Stinger SHT303 HPM Series Battery Terminal with Two 1/0 or 4 Gauge Outputs Stinger SHT303 HPM Series Battery Terminal with Two 1/0 or 4 Gauge Outputs
4.04.0 out of 5 stars
(44) (44)
Price, product page
$32.99"><span style=$32.99" /> $32.99">$32.99
Only 6 left in stock - order soon.Add to cart
"><img src=" /> ">Battery Terminal Connector, Positive and Negative 1 Pair Battery Terminal Adapter Set, Top Post Battery Cable Terminal Con...
Battery Terminal Connector, Positive and Negative 1 Pair Battery Terminal Adapter Set, Top Post Battery Cable Terminal Connectors with 2 Washers, Fit for SUV Van Motorcycle Battery Terminal Connector, Positive and Negative 1 Pair Battery Terminal Adapter Set, Top Post Battery Cable Terminal Connectors with 2 Washers, Fit for SUV Van Motorcycle
(89) (89)
700+ bought in past month
Price, product page
$5.89"><span style=$5.89" /> $5.89">$5.89
Today
"><img src=" /> ">Stinger SPT55301 PRO Series Battery Terminal Works with Both Positive and Negative Terminals
Old Aug 30, 2025 | 10:26 AM
Justinh's Avatar
That Singaro looks interesting. I'm still truckin' with my OEMs.
ingydrummer
Aug 25, 2025 02:26 PM
dbphotos
Aug 25, 2025 01:09 PM
bureau13
Dec 22, 2019 10:25 AM
billy
Mar 24, 2015 07:51 AM
6spd04cobra
Jul 3, 2010 07:58 AM
