Help H3 dead won’t start after unplugging bcm
Old Mar 22, 2021 | 04:58 PM
tonyb5150's Avatar
Default Help H3 dead won’t start after unplugging bcm
Guys I unplugged bcm with battery connected to check connections. It started right up after but it said service traction and 4wd. Didn’t have those before so I disconnected battery
Now I have reconnected battery and truck will not turn over or do anything. Dome lights are on and radio says 1200
Old Mar 22, 2021 | 05:03 PM
Scan and post the codes.
Old Mar 22, 2021 | 05:30 PM
tonyb5150's Avatar
Truck started back up but hvac controls didn’t work. I then turned it off and now pass lock indicator comes on and it won’t start again.
I also had a service traction control and 4wd which I’ve never had before when it was running
i checked codes when it was running and it was a p0650 MIL malfunction
Old Mar 22, 2021 | 05:40 PM
Don't start to scan for codes! KOEO.
Old Mar 22, 2021 | 05:54 PM
wpage's Avatar
Do some searching here for some common situations.
You may need a new battery
Old Mar 22, 2021 | 06:13 PM
When testing any circuit for open or continuity/ resistance, it is imperative that all related terminal pin fit and tension be checked when disconnection of the connector or component, prior to any component replacement.
Old Mar 22, 2021 | 06:47 PM
tonyb5150's Avatar
Fixed. The harness next to the bcm was not fully snapped in. It was connected but not tightly snapped. Thank you
raceit17
Jun 22, 2021 09:57 AM
Echelon
Jul 7, 2017 05:58 PM
atari800
Jan 31, 2016 07:30 PM
amt50
Jun 3, 2010 11:15 AM
ltrayne842002
Mar 18, 2009 01:29 AM
