Headlight adapters
Old Jan 11, 2024 | 02:00 PM
Briman06's Avatar
Default Headlight adapters
I would like to know where I can get headlight adapters for the 7 in headlight conversion to my 06 H3
Old Jan 12, 2024 | 07:31 AM
I have a set, but since they are not being produced currently they will not be cheap.
Plus, I do not sell/deal with single posters for safety reasons.
Old Jan 12, 2024 | 10:23 AM
teahead's Avatar
Old Jan 12, 2024 | 02:45 PM
Originally Posted by teahead
TONS OF INFO IN THAT KRAP FILE you keep suggesting on different HUMMER forums!
See the quoted info below I borrowed from another HUMMER forum where @teahead suggested this KRAP AZZ FILE!
"Please for the love of god do not use this crappy adapter. This was a prototype made like 7 years ago that was never actually used by the guy who made it, but somehow new H3 owners keep finding and think it is a free cheap alternative. Let me explain all the reasons why this is a completely inferior design. I am not discouraging you from printing your own stuff, but this current adapter design is extremely poor and needs to be redesigned because currently it has A LOT of problems.
1.) No retaining ring is used to hold this headlight in place. The way this terrible adapter holds the headlight in place is by using 2 holes on the side of the adapter and you screw in some screws to put pressure on it. It is possible that your headlight can pop out of the adapter if you go over a bump because the headlight is not that well secured in place. The 7in seal beam headlight has been around for decades and it always uses a retaining ring to keep it in place. That was how it was designed to be used, so why use an inferior way to hold it in place?
2.) This adapter does not make use of the 3 alignment tabs that are found on the back of 7in headlights. Again, this adapter ignores all the principles of how the 7” were designed to mount in all other vehicles that come 7” headlights. It is important to have an adapter that you can seat in these 3 tabs found on the headlight so the headlight does not rotate and become crooked. Also it makes it much easier to orientate the headlight in to the correct position when installing.
3.) These adapters are made out of a single piece which is not a good idea. Once you put the headlight adapter on, its not ever going to be able to come off. If you were to pull it off, it would most likely break the studs on the adapter. 3D printed material is not strong enough to withstand that amount of force needed to take it off. In fact, if you are not careful, you can break the studs off the OEM headlight housing because of how GM designed this headlight assembly.
4.) Different sized headlights may not work. This adapter was modeled around a single headlight and multiple headlights were never tested to fit. This is a HUGE problem because the inner diameter of this headlight adapter was specifically matched to the 7” headlight that designer was using for his project. Not all 7in headlights have the same sizing in the back, so it is possible that some headlights could be smaller or larger so the fitment will not be correct.
5.) These headlights were never actually used by the original designer. The guy who originally made this adapter abandoned the project and opted to a different headlight setup. Because these headlights were never actually used, these are basically just a prototype. As a result, no design changes or improvements were ever made to these adapters, so no real world experience was incorporated into the design. Since this guy who made them never did a redesign, it is possible that the new 7in headlight would sit too high or too low in relation to the grille headlight hole. That also goes for the left and right positioning as well. These headlight adapters need careful and precise positioning so the new 7” headlight looks like it is perfectly center in the grille headlight hole or it will look off. I have seen people try and mount these 7” headlights on their H3 without using the right adapter and it is easy to tell because they are crooked and off center."
Old Jan 12, 2024 | 08:36 PM
BLK WLF's Avatar
Great info.
Now we talking H3 here but I assume this will be the same for the H2?
Old Jan 13, 2024 | 01:34 PM
teahead's Avatar
I think H2 you can retrofit 7" easier.
For H3, this all you got:
https://www.hidprojectors.com/produc...onster-shrouds
Old Jan 15, 2024 | 11:06 AM
Originally Posted by BLK WLF
Great info.
This is regarding the H3, I am not overly familiar with the H2 lighting.
Old Jan 15, 2024 | 08:55 PM
Briman06's Avatar
I did purchase the tread stock adapters and realized they were not going to work i just wasted money and tried aftermarket adapters more wasted money that's why I'm reaching out to see where I can find the right ones that fit
Old Jan 16, 2024 | 09:20 AM
My 09 H3 Alpha came with headlights. I used LED bulbs for headlights and the fogs....... called them done. No adapters needed, just a simple re-adjustment.
Of course, that was long after the important stuff like Rock Rails, UCP, winch bumper, exhaust, intake, PP TB, tires, Cam and LS6 springs, HP Tuners, Efan conversion, speaker and sub upgrades with Dynamat and Alpine Stereo....
Old Jan 24, 2024 | 01:59 PM
100+%
My amazon vine account sent me a set of>
H13(9008) & H10(9140/9145) 6000K H13(9008) & H10(9140/9145) 6000K
to test at no charge. This gave me a chance to compare my sylvania ultra super special secret sauce gas halogens. These leds are plug and play, and I did 1 bulb at a time and compared hl and fogs. A HUGE difference in brightness, perfect WHITE, and plenty light.
