Had to have my BCM reset and now have Crankshaft, Tranny and transfercase codes
Old Today | 11:34 AM
Me 2's Avatar
Default Had to have my BCM reset and now have Crankshaft, Tranny and transfercase codes
I was one of the idiots that threw in a used BCM on my 09 H3T and miles went way up and no start, sent the original BCM to have the odometer corrected. When putting the BCM back in miles are correct and truck started. But noticed every start takes a moment and when driving it the truck revs high with less power. Checked codes and have the ones in the pic. I read that there's a relearn on the crankshaft position sensor. Also read that doing 55 mph for a bit and down to 45 and back up helps but haven't tried it yet since my brake lights don't work yet. Not sure on the rest. Does anyone have any ideas on this?
Old Today | 02:08 PM
Multiple transmission codes.
Make sure the battery is fully charged & CLEAR THE CODES.
Drive & scan for codes again then post results.
P0973 1-2 Shift Solenoid (SS) Control Circuit Low Voltage
P0700 Transmission Control Module (TCM) Requested MIL Illumination
P2764 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
P2769 Torque Converter Clutch (TCC) Enable Solenoid Control Circuit Low Voltage
P0315 Crankshaft Position Sensor Variation Not Learned
Old Today | 03:07 PM
Me 2's Avatar
Will do, I did erase them. Will get it out to see, ty
Me 2
Apr 20, 2026 09:43 AM
Michele31415
Hummer H3T
Mar 3, 2026 03:44 PM
madmaxer
Jan 28, 2024 10:39 AM
Vmgreen0110
Nov 1, 2020 02:41 PM
FloridaH3t
Hummer H3T
20
Oct 24, 2018 08:54 PM
