H3 PCV Port clogged ...??
Old Feb 6, 2019 | 03:13 PM
Aaajaws's Avatar
Default H3 PCV Port clogged ...??
My Garage Mechanic told me my PCV port is clogged / plugged. ( Doesn't have a PCV valve .? Have to replace the valve cover which they don't make any more and cant find on line.
Deep freeze this last month …… Some foam in Oil cap and around PCV port and in Air baffle. Random misfires Cyl 4 OBDII codes
Any one else have this issue. He did pressurize the Radiator 20 PSI no leaks ( Head gasket thought to be good ) .
Has anyone taken their valve cover off and cleared / cleaned the port ? Are we / he missing something ?
Jaws
Jaws
Old Feb 6, 2019 | 04:13 PM
Happy Hummer's Avatar
Ok. I'll call b.s.
You can simply take the valve cover off and have at it cleaning out. Then replace the valve cover gasket. Ur done. Get the new hose to boot and your set.
This is really simple and not all that expensive. Even if you purchase your own new valve cover and gasket.
Old Feb 6, 2019 | 05:39 PM
happythree's Avatar
might blow out with air compressor, never did, just guessing. id try b4 tearing apart...
cfarther
May 29, 2019 11:52 AM
caboman
Dec 26, 2018 06:43 PM
woodyw333
Feb 27, 2017 10:10 AM
Theleo
May 24, 2014 06:18 AM
aces
Mar 27, 2013 05:29 PM
