H3 need help for sizing 20" with 35" tire
Do you know if your wheel's are 20x8.5" or 20x10"
Thanks Jeff
ar_h3...
...You say you have 20 x 10 ....according to XD they only come in -12 offset...is this correct?
Do you have 20 x 10 with 35"x12.5" tires and -12mm offset....?
Can you post more pics?
I would like to see how far they stick out the fenders?
Can you explain more where they scrub on the fender lining?
Appreciate if you could give some more info...
yes 20x10 with 35x12.5, i got them used with 200 miles on them im not sure the off set. but if the website says that the 20x10s ARE -12mm offset then i guess that is what these are. it has been snowing here in central Arkansas so its kinda hard to see the pics because its so bright outside, but hope this helps you
Thanks for the info... I know in the rockstar 775 you can only install the 20x8.5" because it has a -10 off set and backspacing is 6", now if you go with the rockstar 775 wheel in 20x10" it has a -24 offset and backspacing is 5" so your wheel will stick out 1" by starting off then the wheel is 10" so this will make the weel's stick out to mutch with the rockstar 20x10"...... Now if you go witht the xd monsters wheels 20x10" the off set is -12 and the back spacing is 6" so this wheel will fit better on the hummer...
so all come down to this if you go with rockstar wheel you need 20x8.5" abd if you go with xd monster you need 20x10"... now this sizing is for installing 35" tire on hummer h3.
Thanks Jeff
Thanks Jeff
They answered all my questions. The scrubbing....there maybe some work with the heat gun could already help.
Ur wheels and rims stick out 1-2" as it looks on the photo...that would fit also with the offest of -12....this is exactly what I need with the factory fender flares.
