H3 in limp mode AND stuck in 4HI after tcase shiftfork, range fork, shift rod rplcmt
Old Jul 7, 2022 | 09:20 AM
DrSatanPro's Avatar
Default H3 in limp mode AND stuck in 4HI after tcase shiftfork, range fork, shift rod rplcmt
Hey guys. I have a 2007 H3 hummer I just replaced the transfer case plastic to metal shift forks, the range fork and shift rod inside the tcase. After putting the tcase back on and then the encoder motor and battery, the hummer is now in limp mode. It’s also stuck in 4HI and won’t go into 4HI lock or 4LO. Any suggestions of where to start troubleshooting this? Do you guys think it’s the encoder motor that now needs replaced or is it something like I need to fry out the ecm or clean the TB or something. Any and all sugg appreciated. Thanks!
Old Jul 7, 2022 | 10:09 AM
Are we to assume you did the work correctly and kept all the Planetary Gear marks lined up if you pulled the gears?
To do the basic shift fork replacement, the culprit is the Lock Shift Fork (not the Hi/Lo Fork) and you can replace that keeping all the gears in place. Example leave the gears alone thread by CWC Goodbye plastic
Old Jul 7, 2022 | 01:04 PM
DrSatanPro's Avatar
This unfortunately was not a basic shift fork replacement. There was extensive damage done by a body shop that didn’t know what they were doing when putting on an encoder motor for me and broke several parts inside the tcase. However, we went through it with a fine tooth comb and replaced whatever needed replacing. All the gears were obviously lined up and we made sure everything worked properly inside the tcase before even putting it back on the hummer. This is the first time the hummer has gone into gear since it originally broke down a while ago. It took us a ton of work and time and money which is why it’s been a while but now it just goes into limp mode when turned on. I never replaced the encoder motor again after the shop replaced it and I’m wondering if bc they put the encoder motor on when it wasn’t the encoder motor and it was the shift fork if the tcase destroyed that encoder motor that’s on it even though it was a new encoder motor bc the shift fork issue hadn’t been rectified yet….
Old Jul 7, 2022 | 01:26 PM
To diagnose the shift encoder motor remove from Tcase, leave plugged in and see if it will change position.
If it works, then your issue is the Tcase internals.
What codes are you receiving?
Old Jul 7, 2022 | 01:53 PM
The encoder motor just turns a square peg to the degree you select with the dash T Case buttons. You could try a new one if you want, but I would test the current one and its harness connector. Easy stuff first.
Never heard of the plastic shift fork doing any damage other than failing to function, ie. deflect or jump out of slide collar grove.
If the timing marks on the planetary gears are not lined up, you will have issues similar to yours......... or worse.
Old Jul 7, 2022 | 04:34 PM
Bu11Fvk'nSh!t!
ONLY 1 Way to install the encoder motor!
"Limp mode" would not be caused by a transfer case error, stab sys on the dash could cause it.
You need help? SCAN ALL MODULES & POST CODES!
Old Jul 9, 2022 | 03:58 PM
DrSatanPro's Avatar
No codes are being thrown zero zip. That’s why I’m so confused.
Old Jul 9, 2022 | 04:37 PM
What scanner/scan tool/code reader are you using?
Does it do this?:
Gadget? Get a plug and play $150 >>>>> SCANNER: GM General Motors Diagnostic Scanner Code Reader ABS SRS SAS Scan Tool Vident
iLink400 Full System Single Make Scan Tool is the most cost-effective professional multi-system scanner that delivers OE-level diagnosis for all electronic systems of different car brands. The vehicle coverage includes 1996 to 2019 Chevy, GMC, Cadillac, Buick, Pontiac, Saturn, Chevrolet Truck, Chevrolet MPV, Pontiac APV, Hummer, and some selected 2019 models. The manufacturer is continuing updating the software to cover the latest vehicles. It has not only the basic functions such as reading/erasing codes and live data, but also advanced functions including actuation, adaptation and programming. In addition, it ensures you to access the most commonly required service features like Oil Service Light Reset, Throttle Body Alignment, Electronic Parking Brake Service, Battery Configuration, Steering Angel Sensor Calibration, CBS Correct, and others.
It reads and erases Diagnostic Trouble Codes from most (if not all) electronically controlled systems, including Engine, ABS, Airbag, Automatic Transmission, Immobilizer, Climate Control, etc.
Answers for Frequently Asked Questions on Functions:
Engine:
  • Crankshaft position (CKP) relearn
  • Camshaft position (CMP) relearn
  • Oil life reset
Transmission:
  • Preset transmission adapts
  • Reset transmission adapts
  • Reset transmission oil life
ABS:
  • Automated bleed
  • Brake press sensor calibration (for changing sensor)
  • Yaw rate sensor recalibration (for changing sensor)
SIR/SRS:
  • Setup new SDM (for changing new SIR/SRS ECU)
  • Setup SDM primary key in BCM (for changing new SIR/SRS ECU)
Others:
  • Copy and paste TPM information (for changing new Romote Control Door Lock Receiver ECU)
  • Tire type / Pressure selection (for changing new TPMS sensor or for changing new tire)
  • Program Key Fobs
Old Jul 11, 2022 | 01:10 PM
You may need a better scanner that will read ABS fault codes.
Every time I have seen STABSYS faults it has been ABS related. With an ABS related fault you are not able to switch Tcase modes unless you do it manually.
CMBAMF
20
Dec 13, 2018 07:29 AM
HummerH3_2006
Mar 11, 2018 10:44 AM
Murf Davis
Aug 2, 2017 09:25 AM
Kkneat
Apr 26, 2017 07:10 AM
Oodles
Dec 31, 2014 05:38 AM
