H3 i5 HP&MPG Gains With Your Mods
Old Mar 6, 2020 | 08:25 AM
Hummerbird's Avatar
Default H3 i5 HP&MPG Gains With Your Mods
Good Morning All,
Just curious to see what gains people here have seen with their mods on the i5 Hummer h3 engine. If you could list all your mods and where your HP and MPG currently stand, thank you!
Old Mar 6, 2020 | 08:51 AM
I no longer have my 07, but it had all the performance and off road mods on MTZ 305s, weighed in close to 6000# with me and in it (put it on the local landscape company truck scale). That was one of the best truck I ever owned and I had it 12 years.
Performance: Air Doc Intake with AFE Pro-Dry Filter, Port/Polish TB, PCM of NC PCM Tune and Efan conversion, MagnaFlow Cat Back Exhaust and CFS Aluminum Radiator. Got no idea what the end HP/TQ was, no point in figuring it out. It ran strong and even made some FS V8 Pickups look silly in sand drags when they found out they were done in by an aluminum 5 banger. Not the grunt of a stock Alpha, but pretty stout with better MPG.
MPG was improved. Biggest thing is drive with slow easy starts and keep the Eway speed to 75 or less. I saw a high of 19.5 all highway in the summer in calm conditions with tires at 40PSI on one trip, regularly managed about 16.5+ combined. If it did not have a BA Winch bumper and rock rails, probably would have done better MPG without that extra weight, and even better with 285s instead of 305s. Forget all that as soon as the wind starts to blow, H3s are a brick when bucking headwinds.
I can also say that I made a 150 mile run couple summers back with two 12' kayaks on roof racks at 70MPH and got 14MPG pushing it all through the wind.
Old Mar 6, 2020 | 04:08 PM
rockhound's Avatar
06, cold air intake, cat back exhaust, 33s, baiscally stock i get 18.6 but thats running colorado mountains at 9000 ft. im at 3-5 over posted limit usually when its safe.
just installed my new pcm from pcm nc ill see what it adds or takes away this week.
Old Mar 6, 2020 | 08:21 PM
Hummerbird's Avatar
Nice!! Please share the results of your PCM tune from NC PCM. Curious to see how that turns out as well, I always hear good stuff about them and PCMforLess
Old Mar 6, 2020 | 08:31 PM
Hummerbird's Avatar
Nice Doc!! I'm sporting your Air Doc (tyvm, it was such an important upgrade), PTB from Supermodulation+SuperSparkz, iridium spark plugs, on 33's BFG K02's. Undecided about the Magnaflow Cat Back exhaust but I am definitely going to get the PCM tune. I took your advice on the slow easy starts and keeping Eway speed to 75mph and less and the H3 seemed much happier than at higher speeds than 75mph. All in all, you loved you i5?! I really like mine and at first I wasn't sure how the i5 was going to be but with these upgrades my H3 i5 has been responding so well.
Old Mar 11, 2020 | 12:02 PM
rockhound's Avatar
Have had the PCM tune installed for a couple of days now.
1. I had them adjust the idle up a bit. sits at about 750 rpms. this made a nice change in the driveability. This alone makes the tune worth every penny. smoother idle, smoother off the line, no rpm dive as i come to a light. this should have been the factory setting.
2. i had them do an 87 octane tune, so not really a heavy perfomance tune, but where I am 87 octane is midgrade and at 8700+ ft altitudes, pinging can be a problem with aggressive changes in timing. rig is defintiely smoother, quieter and faster off the line (not a race car). Top end I did not see a huge improvement although after the third day I did gain 3 miles per hour going up one of my local hills. About 3 miles of 7-8 percent grade. Before third gear would maintain about 48-49 mph without downshifting into 2nd gear. Yesterday the h3 hit 51 in third on the same hill. Weird cause earlier in the day it stalled out again at 48ish. no real difference in temp or wind so not sure why it went faster. I'll have to see if that is a consistant change in power.
3. temp guage reads a bit cooler, sitting closer to 1/2 rather than 5/8s
4. I also had them bypass the passlock system. This saved me from having to bypass the system for a remote start.
5. I put the rig through emissions yesterday with the tune installed, passed colorado emissions with no issues.
overall I am happy with PCM of NC, I over nighted the computer to them on a Monday, they turned it around in a day and it was back in my hands on Friday.
Old Mar 11, 2020 | 12:12 PM
Hummerbird's Avatar
Awesome! Thank you Rockhound, this info helped a lot. I'm going to ask for my RPM to get adjusted as well. I get those darn RPM dives at every stop light. I'll be tuning to 87 octane too
Old Mar 11, 2020 | 12:14 PM
rockhound's Avatar
I cannot say whether I gained any gas mileage, but even just coming home from a grocery trip i have pretty heavy grades and im doing 60 plus in third most of the time, so gas mileage improvements will hide for sure
rawksteady121
Aug 15, 2014 07:59 PM
Mad rebel
Mar 21, 2014 04:29 PM
KA H2
Sep 1, 2013 07:07 PM
maddness038
Nov 12, 2010 12:12 AM
T REX
Mar 8, 2008 02:05 PM
