H3 heater core
Old Dec 6, 2023 | 12:10 PM
Marleygra's Avatar
Default H3 heater core
I have to replace the heater core in my 07 H3. I’ve been told both that I need to reclaim the refrigerant and disconnect the a/c to do the job and also that I can replace the heater core without disconnecting the a/c. Just trying to find out which because I don’t want to have it torn apart then find out I need it emptied with no way to drive it to a shop. Also don’t want to deal with the a/c if I don’t have to. Thanks
Old Mar 15, 2025 | 07:34 PM
Txbgdawg's Avatar
Default Changing the heater doesn't have anything to do with the AC
They are two completely separate entities the only way they connect is using the same air which blows across the evaporator coil is the same air that blows across the heater core.. no refrigeration exchange there
Old Mar 15, 2025 | 07:36 PM
Txbgdawg's Avatar
I guess I could be wrong ...drain the refrigerant ..... WTF
Old Mar 18, 2025 | 09:29 PM
Revmatch's Avatar
Replacing the heater core requires removing the instrument panel and that drives disconnecting the A/C. Ask me how I know.....
Old Mar 19, 2025 | 08:52 AM
To get the heater core out, it comes out as a unit in the HVAC exchange box so there is NO way to do that job without disconnecting AC lines. If you are worried about the AC Refrigerant Police coming to see how you evacuate the refrigerant then go get it evacuated before you start your job.
This video will get you thinking about what you are in for. Perseverance is the word. Best of luck, you can do it.
JAC-H2
May 6, 2020 07:47 AM
x2nervisx
Mar 29, 2020 08:37 AM
sinful7
May 17, 2016 10:28 AM
victor.cary
Mar 11, 2014 04:14 PM
fishaholic
Mar 27, 2007 01:27 PM
