H3 coolant leak in a pipe at the rear of the engine
Old Aug 4, 2023 | 07:26 PM
h3nz's Avatar
Default H3 coolant leak in a pipe at the rear of the engine
Hi all, if its OK I'd like to ask a question about a pipe leak I have found in my H3 3.7. As per the picture Ive found a hole in a pipe in possibly the worst place you could ge one. It appears to be a pipe to the heater or similar. Where would I find a replacement and I don't suppose anyone would have a suggestion on how to go about changing this part?
thanks
Old Aug 4, 2023 | 08:05 PM
Wrong forum! The H3 heater core is connected here:
Old Aug 4, 2023 | 08:09 PM
h3nz's Avatar
Sorry, did I put this in the wrong place? Yea, its the pipe the heater hoses are connected to that appears to have the hole.
Old Aug 4, 2023 | 08:13 PM
h3nz's Avatar
PS, My H3 is Right hand drive
Old Aug 8, 2023 | 01:43 PM
Welcome.
MOVED to the H3 section where all H3 questions go. Are you talking about #11 below? PIPE. Heater = Part Number: 12564053 Supersession(s): 12624499 which is no longer available. Might be tough to find one. You may have to remove it, repair it like through a radiator repair business, then reinstall?
Old Aug 8, 2023 | 01:56 PM
h3nz's Avatar
Hmm, perhaps I could replace the whole section with a new flexable pipe?
Old Aug 8, 2023 | 02:05 PM
h3nz's Avatar
I think its differen
t from the diagram due to being a right hand drive, I'll need to try and trace the pipes that dissappear around the back of the engine.
JrBlanchard24
Aug 26, 2021 08:44 AM
armando99
Oct 16, 2019 04:15 PM
TylerCorrect
Aug 23, 2019 08:41 AM
hummerray
Feb 15, 2009 05:51 AM
dizzy
Apr 22, 2008 09:34 PM
