H3 Alpha is leaking something. Need help
Old Nov 22, 2022 | 03:37 PM
socalhummer's Avatar
Default H3 Alpha is leaking something. Need help
Hi everyone. My H3 is leaking in two places in the front. It doesn’t seem like oil because it looks slightly pink. I just moved to Wisconsin from CA and I don’t have a mechanic here yet. My husband travels a lot so I have to figure this out myself. I’m not sure if it’s something horrible and I should tow it or if it’s ok to drive. I have 153k miles on it. I’m open to suggestions. Thanks
Old Nov 22, 2022 | 09:48 PM
Old Nov 23, 2022 | 11:38 AM
Welcome to HF. You are going to have to get on the ground and look under it to see where it is coming from. From the pics it is possibly Transmission Fluid or even Coolant?
Do you know how to check Transmission Fluid level? Does the Coolant Reservoir have the proper level of coolant?
When was the last time the Trans Fluid and Filter were changed?
Old Nov 24, 2022 | 11:55 AM
Thank you for the help. I looked and it and it was out of transmission fluid and power steering fluid. I had it towed to the mechanic. I appreciate the help because I might have continued driving it and done further damage.
wpage
Oct 8, 2021 04:24 PM
zefrum
Private 'Wanted' Classifieds
22
Jul 29, 2021 05:50 PM
Bone
Apr 19, 2019 05:26 PM
Sundrop Addict
Feb 23, 2010 05:15 PM
Snow Yeti
Jun 4, 2008 10:42 PM
