H3 Alpha Engine Noise - High Pitch Reciprocating from Engine Area
Old Dec 24, 2014 | 09:55 AM
zefrum's Avatar
Default H3 Alpha Engine Noise - High Pitch Reciprocating from Engine Area
Just noticed the high pitched noise; probably because its cold and wet in NYC now?
The only mod Ive done to the engine is to trim the cooling fan blades with a dremel for the Air Doc to clear the blades.
Heres the link to the mp3 sound file on my google drive:
https://drive.google.com/file/d/0B1M...ew?usp=sharing
Thanks!
Old Dec 29, 2014 | 06:51 PM
carbuff91's Avatar
have you put on a new fan belt? Could also be the alternator bearings or water pump bearings.
Old Mar 6, 2020 | 04:27 PM
Mack Mary Anderson's Avatar
Did you ever find out what the noise was? I’ve got the same noise and thinking it’s internal.
Old Mar 6, 2020 | 05:43 PM
Over 5yrs later, the source of the noise would have exposed itself by now.
Start a new thread!
In the meantime, remove the serp belt and start it up(without belt), and check if noise stopped.
Old Mar 7, 2020 | 10:03 AM
zefrum's Avatar
Ha ha, well I dint have the noise anymore 😂
I dont recall if it went away on its own or if it was the Dallas Cadillac dealership replacing my power steering pump and also the alternator. (They broke the alternator housing putting in the replacement pump)
I also dont remember if it really needed to be replaced b/c they were giving me a hard time (they also tried charging me for a new battery saying I dropped it off dead...)
Suffice it to say, The only other thing Ive done to her in the engine bay is to replace the belts last year; and Im betting the noise came from the belts being old in NYC/Dallas winter weather. (I live in Houston which is warmer and wetter than Dallas)
I hope this helps, Cheers!
popocamaro1
20
Dec 17, 2015 08:27 AM
palmid
Jan 7, 2011 05:51 AM
THE BEAST
16
Oct 23, 2009 03:30 AM
Willy
Jan 29, 2008 03:46 AM
ApexLongimanus
Dec 12, 2007 08:40 PM
