H3 2010 with ticking sound
My H3 has a ticking sound when first started in the morning and stops when I drive the vehicle. Sometimes the engine is idle if the sound goes away. Think it’s a lifter or an exhaust manifold. How can it be diagnosed without tearing the vehicle down.
Welcome to HF.
Model and Miles?????? Needed for every question related to a possible mechanical issue.
1) Open the hood, check the oil level. Ticking is sometimes caused by low oil allowing lifters to dry out.
2) Start the engine, get out, look and listen, try to determine where the noise is coming from.
Welcome to HF.
Then it is a 3.7L I5. You should be aware that he Atlas Series engine has hydraulically actuated timing chain tensioner that requires the oil pressure to first come up to add the required tension to the timing chain. Over time the chain will stretch, but the tensioner has ratches that will eventually allow it to click over to the next position to correct for the slack in the chain. Sort of like self adjusting brakes worked.
When you first start the cold engine, if the chain is loose and before the oil pressure can come up to take up the slack, the chain may contact the insides of the front cover. It sounds like a rattle that immediately goes away.
What is happening is the chain is loose enough to slap but not yet loose enough for the tensioner to click over to the next position. Not all will do this, but a bunch can for a while. If this persists for a long time, you may have a timing chain that stretched too far, or tensioners that are worn and need to be replaced.
This can sound like a ticking depending upon the degree of sound. Since I/we cannot actually hear what you believe to be a problem, we really cannot offer any definitive diagnosis.
Hope this helps.
Hope this helps.
New06H3Used
Nov 19, 2018 11:22 AM
quadblaster240
Dec 22, 2009 02:25 PM
