front jounce/bump stops
Old Aug 26, 2019 | 07:51 PM
Justinh's Avatar
Default front jounce/bump stops
I see my front suspension bump stops are toast. So, I've got questions about them before I do anything. I've cranked up the torsion bars a bit to level it.
At stock height they almost ride on the lower A-arm. This doesn't sound good and that it would reduce the shock action. Any negative affect of this?
Do I need to be worried with replacing them? Any need for aftermarkets, or are the OEMs as good as it gets?
Old Aug 26, 2019 | 08:37 PM
My OEM '07 bump stops still look new, however I've changed oem shocks many years ago to monroe reflex monotubes.
Old Aug 27, 2019 | 08:08 AM
They are progressive dampeners. The stock ride height of the suspension is designed to maintain contact with the bump stops at all times.
Extended bump stops were available at Trail Duty, not sure why you would need them or whether they are readily available for shipping.
My truck has the torsion bars adjusted and there is a solid 1" + of space between the LCA and Factory Bump stops. Whoever owned my 09 Alpha before had the suspension set so low it completely toasted the original bump stops. In fact, one side was almost gone it was missing such a big hunk. Replacing them with OEMs is like a 15 minute job. Google it, there are vids out there and already a similar post on the front page of HF.
Old Aug 27, 2019 | 07:39 PM
Justinh's Avatar
10-4. Thanks.
Old Aug 28, 2019 | 06:17 AM
15295277 - Buy 2
Old Aug 28, 2019 | 06:55 PM
Justinh's Avatar
To be sure, Tainter, you are saying to just use the rear bumps on the front if it is raised up?
Old Aug 28, 2019 | 08:02 PM
Those are rears..
Read Doc's post above again..
You should not be riding on the jounce bumpers!
Replace the shocks!
Here's a video with many issues: (notice the distance between the lca and still original shocks):
Old Aug 29, 2019 | 06:21 AM
Sorry, posted the wrong #
Correct # for the Dampeners. 15783030 $20 on ebay
You can order them online here, they are #7 on the diagram. You can also get the directly from any GM dealer regardless of make.
FRAME. Fits: 2009 Hummer H3 | Nalley Buick GMC Brunswick
wpage
Aug 31, 2019 05:59 PM
HawaiianH3
Dec 9, 2014 02:55 PM
Brodie
Nov 17, 2012 08:29 AM
psych0
Apr 28, 2010 07:25 PM
psych0
Apr 22, 2010 06:13 PM
