Front end clunk sound
Old Apr 15, 2025 | 09:42 AM
caboman's Avatar
Default Front end clunk sound
Hey Folks, any help would be appreciated...
When I am turning my steering wheel sharp, close to the max, like when backing out of garage or turning into a parking spot, I get this clunk sound in my front end. I already changed the lower control arm on the passenger side- but it didn't solve the problem.
This issue has been happening for over two years and has only gotten slightly worse.
No shimmy's, no steering issues at normal speeds. Only the very slow speed sharp turn clunk as described.
California H3, 2006, auto, inline 5 cylinder, garaged its whole life, not a spec of rust. 145Kmiles.
Anyone else have this issue?
Old Apr 15, 2025 | 12:03 PM
Jack up both front tires (chock the rears both sides) have someone turn the wheel while you safely look and listen for the mystery clunk. Check all the steering as well as the front diff bushings (3 total).
Old Apr 15, 2025 | 12:38 PM
X2 what Tainter said.
I'm guessing front Diff bushing. Only other thing it could be is ball joint(s) and you replaced one lower A Arm so I assume that ball joint is new?
Old Apr 16, 2025 | 08:27 AM
caboman's Avatar
Yes on the ball joint. It was built into the lower control arm
Old Apr 16, 2025 | 08:42 AM
caboman's Avatar
Thanks for the info on the front differential bushing(s). I will definitely look into this. This has been a fantastic vehicle, and while I thought about replacing it with something newer- I decided to drive it til it's dead. As my friends Dad always said, the best vehicle out there is the one that is paid for and runs well. This H3 checks both boxes :-)
Old Apr 16, 2025 | 09:36 AM
OK, that is one of four. The Uppers have non-serviceable ball joints and they do wear out ... then you have to replace the Upper A Arm if that is the issue.
Good luck
NFS
Mar 8, 2025 03:51 PM
IsaiRp
Feb 12, 2024 10:47 AM
WoogiesH2
Mar 8, 2011 09:58 AM
RICKNICKS
Jan 16, 2008 07:27 AM
Sugardaddy
27
Nov 13, 2006 12:52 PM
