Front diff leaking and driver side cv joint
Old Jan 10, 2013 | 06:51 PM
Hummer79's Avatar
Default Front diff leaking and driver side cv joint
I got to looking under my h3 and the cv joint for the driver side had fluid on it from what it looks like the seal leaking and also the same way where the driveshaft goes into the front chunk I plan on doing it all this weekend done this before but not on a hummer or a front end only a rear end and i was wondering if this is common with 100k miles and how long and hard is it to do
Old Jan 10, 2013 | 08:34 PM
Happy Hummer's Avatar
The seal for the front snout is what ur talkn bout right?
Chris
Old Jan 10, 2013 | 11:44 PM
Hummer79's Avatar
Yes it's not leaving a spot on the ground but I wanna get it fixed before its to late and there is fluid everywhere also the shaft is wet with fluid along with the cv joint where it comes out of the chunk on drivers side
Old Jan 11, 2013 | 12:41 AM
Yeah, the seals leaking on any IFS rig is pretty common. There is a writeup here on half shaft replacement. Follow those steps and replace the seals. Not a super hard job. The first one will take a while but you will be much faster on the second side.
Old Jan 11, 2013 | 10:31 AM
happythree's Avatar
I think the driveshaft seal is a little more complex, caution,read all about it first.
Old Jan 11, 2013 | 03:35 PM
Seals last longer when you stay out of the mud.
Old Jan 27, 2013 | 03:51 PM
Tomcatoib's Avatar
i had my hummer making noise at front driver side dont know what i need to replace cv axle or the joint i is leaking on the four bolts beside the skid plate, i have pic but dont know how to post it thanks
Old Jan 27, 2013 | 04:41 PM
2wheelmonster's Avatar
After a 100K alot of things go bad but once you start it and finish your gonna go I just save alot of money by switching to....
Old Jan 27, 2013 | 05:06 PM
Broken Halo's Avatar
Without the pic I can't be sure, but it sounds like the same problem I had last week. No noise, but leaking. Dealer replaced front left output shaft and seal, covered under 'Powertrain Warranty'. Apparently this is a common failure.
mb7050
Sep 13, 2014 12:56 PM
palmxjjsi
Jul 6, 2011 02:36 PM
jash3
Feb 17, 2010 03:22 PM
tzhmmr
Jan 13, 2009 08:22 AM
alrock
Nov 9, 2007 07:48 AM
