Front brakes restoration cheap
Old Apr 24, 2025 | 07:51 PM
Default Front brakes restoration cheap
My '07 is in the garage for restoration getting my TLC whenever my time is available on any given day started here> Headlight
My brake pads-rotors-hoses are junk scrap rotted ....
I thought I could save the calipers however I was only able to get 3 of 4 pistons to retract/extend on the drivers side caliper which immediately sent me looking for a rebuild kit along with a NEW set. All here ready to install:
Old Apr 25, 2025 | 10:29 AM
Old Apr 25, 2025 | 11:49 AM
ski.dive's Avatar
Great deal!!!!
Old Apr 25, 2025 | 12:20 PM
Took my time searching around the WWW. Replacement parts are getting cheaper as time goes by.
Vine just delivered a light bar for me to test & review.
Strong magnets suction cups bright led lights with 21 Flashing Modes.
Old Apr 25, 2025 | 01:41 PM
wpage's Avatar
Nice work Hummerz...
Brake job B4 and after, amazing!!
Well done.
Old Apr 26, 2025 | 01:02 AM
Happy Hummer's Avatar
Looks cln
Old Apr 26, 2025 | 11:28 AM
While installing the new brake hose on the passenger side I bumped the engine mount heat shield and heard a rattle. Pulled the 10mm head bolt and installed a bracket I found in my hardware tool chest. Shield is now secured tight no rattle.
I also found the intermittent transmission fluid leak coming from a band clamp that I cut and replaced with 2 14-16mm heavy duty hose clamps.
Old Apr 26, 2025 | 02:53 PM
Justinh's Avatar
You might could sell those shield clamps, as the shield is probably no longer made
Why did you leave the cut hose crimp flare on the pipe?
Old Apr 26, 2025 | 06:51 PM
#1-That bracket is from an old aluminum screen door I took apart as I always save hardware to repurpose and currently have a 5 drawer tool chest + a couple toolboxes filled with hardware: nuts- bolts- screws- washers- brackets- etc+++++++a lot more... that I've collected over many decades.
#2- I left the cut crimp clamp on the tube for photo purpose only.
I've cut many tubing crimp clamps over the years and I simply made this cut with a cut off wheel attached to my 19.2v craftsman drill driver just deep enough to split the remaining with my slotted screwdriver. After removing the crimp clamp I noticed the hose was split on the top & cut 1/2" from the hose then proceeded to secure the hose with 2 heavy duty clamps.
Old Apr 27, 2025 | 11:21 AM
wpage's Avatar
Default Nice
Hummerz, agreed...
Advantages of reuse cannot be understated. Like DaVinci, being creative in solving problems in all things is a art and science...
Like the way you re-purposed, to fix a example of many of the challenges folks with older classic and other vehicles face.
Keep up the great tips ~!
BOHICA
Apr 6, 2025 06:07 PM
hummerz
Off Topic
May 25, 2024 10:23 AM
WestAuctions
Jan 26, 2024 06:21 PM
beitodesstrafe
100
Aug 3, 2011 05:44 PM
AZG1164
Dec 11, 2010 11:28 AM
