Front axle seal for H3 with adventure package
Old Mar 28, 2013 | 06:42 PM
Jogi's Avatar
Default Front axle seal for H3 with adventure package
I need to replace the front axle pinion seal on my H3 2006. It has an adventure package. Does anybody know if the seal is different then the regular H3.
I'm in Central America and my mechanic who took it apart said that the seal consists of two parts not one as show in the Internet graphic.
Old May 4, 2013 | 10:50 PM
namyzzo's Avatar
Default 7.6" ifs pinion end yoke seal
Do a bing search for this 74020004
this should be what you need ( has the seal sleeve that stays on the pinion End Yoke, has the seal that presses into the diff housing...etc.. and more )
Old May 4, 2013 | 11:23 PM
happythree's Avatar
if you read the instructions for replacing pinion seals you will find that it is not as simple as replacing axel ,and other seals.
its a critical procedure. if not done right,expensive problems follow.
Old Apr 25, 2022 | 11:42 PM
namyzzo's Avatar
4-26-2022
40006690 = Seal/Sleeve (aka: Speedy Sleeve)
40035125 = Pinion Yoke with Seal/Sleeve already installed.
40024218 = Housing Seal
74020004 = Kit
motley1987
Jan 10, 2022 01:08 AM
brothapig
Jul 22, 2021 04:54 PM
mikemoreno
Sep 14, 2013 05:11 PM
Nmocean
Feb 10, 2013 07:42 PM
chip4065
Jul 1, 2012 09:12 PM
