Found an issue with leveling kit,,,
Old May 8, 2014 | 10:58 PM
  #91
Originally Posted by grogers
I recently had readylift 2.25"front and 1.5' rear installed with 35" tires. two days later had to replace cv joints. just got it back today and have serious vibration. measured from axle to fender at 25". looks like Im screwed. can I just lower the torsion bars to 23.5" or will I need to take the lift off.
You can try to back off the adjustment bolts and see if you can get back down to 23 1/2/. Sometimes keys are indexed by the installer so they will have to do less "cranking" and achieve a lift that is WAY TO HIGH like 25".
If you can't back them down enough you will have to buy new ones or re-index the keys you have (not sure with the readylift keys).
Old May 9, 2014 | 03:41 PM
  #92
byeatts's Avatar
Originally Posted by davidducati
Ok, byeatts I have two h3s, an 07 and a 09 3T. I run 33" on the 07 stock set up. I run 315/70/17 on the T with the front at 24". Per a bad alignment I replaced the cv joints at 25,000 miles and now with 50,000 miles and still at 24" I decided to try this mod. I built two spacers, dropped the front of the diff 1" and to my surprise, the T cv's are a lot closer to the 07! MAJOR DIFFERANCE! Next, I checked the angle on the front driveshaft on both to see the change measuring from the trans heat shield to the shaft, maybe a 1/16 difference! No added stress in the driveshaft boot at all. Next, check the mount on the rear diff mount, not bound or stressed at all. If I have to replace the rear bushing often I will mod the crossmember to drop the rear an inch because I can! The less stress on the cv's is what rules here, from cost savings to reliability it is a no-brainer!
Nice job! The mod is Soilid .
Old May 10, 2014 | 04:10 PM
  #93
amrg's Avatar
How many miles do either of you have on this setup so far? Any wheeling done too? Any issues?
0sixH3
Nov 25, 2012 07:14 AM
GarrettMoore
May 5, 2007 11:29 AM
aetherH3
38
Dec 13, 2006 10:35 PM
HUDYHUE
May 6, 2006 12:57 AM
stallioncustoms
Jan 14, 2006 04:42 PM
