Flashers stuck on
Old Jul 25, 2025 | 07:50 AM
fcaramadre's Avatar
Default Flashers stuck on
I have a 2007 H3 and i am having a problem My flashers are stuck on, I have unplugged the hazard switch and they are still on.I have unplugged and cleaned the connectors to the bcm still stuck on. I have found the wiring diagram but have not found the pin-out for the connectors so i can see if i have a short to ground on the input.Does anyone know where i can get that or have any advice or had the same problem? I believe the bcm may have an internal problem but want to be sure before i get another one.
Old Jul 25, 2025 | 09:09 AM
maybe check the wiring for the trailer hitch harness at the rear bumper.
Old Jul 28, 2025 | 02:31 PM
skilescm's Avatar
Attached is the BCM connector pinout.
File Type: pdf
Old Jul 29, 2025 | 05:27 AM
fcaramadre's Avatar
Thank you thats just what i was looking for!!
Old Jul 29, 2025 | 07:57 AM
skilescm's Avatar
  1. Disconnect the hazard switch (S205) at the dash
    • If lights stop: bad switch
    • If lights stay on: move on
  2. Disconnect the multifunction switch (Turn signal stalk)
    • If lights stop: faulty stalk switch (very common GM failure)
  3. Disconnect the input to the BCM (connector C2 pin B5 - PPL)
    • If lights stop: switch or wiring issue
    • If lights still flashing: suspect BCM is internally stuck
hulhi
Oct 18, 2024 01:35 PM
upnorth
Sep 5, 2023 05:12 PM
Boutbusiness
Dec 1, 2022 01:59 PM
Don_D69
Feb 4, 2022 11:06 AM
dognut
May 17, 2017 05:59 PM
