Engine surging
Old Mar 24, 2021 | 06:33 PM
07h3a/cmech's Avatar
Default Engine surging
I have a 2007 hummer h3 3.7L adventure package. During rapid acceleration engine begins to surge up and down about 200 to 300 rpm drop mainly through 1st and second gears but if I manually turn off traction control via the button next to the rear locker button, it doesn't surge at all. Any insight would be much appreciated.
Old Mar 25, 2021 | 09:25 AM
Welcome to HF.
Miles on the Odo??????
Read this: Acts like it wants to stall/rough idle -No CEL -What To Do:
Old Mar 27, 2021 | 07:00 PM
Welcome to HF.
192k, I've already replaced the maf, map, tb, air filter, sparkplugs and checked harness. I'm at a loss.
Old Mar 28, 2021 | 12:09 PM
Teamzr1's Avatar
Check and report if there is any error codes, some error code readers are junk and only report generic DTCs
Use one that does GM enhanced and checks all controllers in vehicle
Check fuel rail pressure, what is it ?
Last time the fuel filter was replaced ?
Bad gas or filled with E15 gas which most people do not even look at the pumps and feds made allowable 4 years ago
Else get like a OBDLINK OBD-II MX+ scanner (Amazon) less then $100, works on cellphone and laptops using MS windows
and look at what the fuel trims vales are.
Larger the positive values are, the leaner engine is running, negative values are rich
Check for ANY air ot exhaust leaks, and possible the O2 sensors are corrupted or too old
Old Jul 26, 2022 | 08:31 AM
StratLover58's Avatar
Default Similar Problem
My engine in my 06 H3 surges during accelerating only when the A/C is on. Any input on this?
Old Jul 26, 2022 | 09:47 AM
How many miles? When was the last time you cleaned the Throttle Body? MAF?
Not a good practice to dig up old threads to ask a question.
Old Jul 26, 2022 | 01:09 PM
I bought it last Aug. (2021) odometer read 230k but the engine had been replaced at 160k and the trans replaced at 220k. I, personally haven’t clean the throttle body.
As far as it being an old thread I just searched for “engine surging” and found this thread.
marine60
Apr 22, 2015 07:45 PM
XxCC3xX
Sep 2, 2011 09:49 AM
Jinmajay
Feb 3, 2010 06:55 AM
hotrod
Aug 26, 2008 01:12 PM
hummer1
Mar 15, 2007 08:34 AM
