Engine rebuild
Old Feb 6, 2023 | 12:45 PM
NolesFan26's Avatar
Default Engine rebuild
Due to low oil pressure warning and a knock at startup followed by a rattle at high RPMs, I’ve decided to tear the engine apart. Prior to this I’ve already replaced the oil pump (due to low oil pressure), timing components, as well as bearings, prior to this tear down due to knocking as well. I’ve removed the camshafts, but as I was looking the intake camshaft’s guides appear to be worn really bad compared to the exhaust camshaft guides. Is this normal? Can a machine shop fix this or would buying a new head be warranted? Thanks!
This is the Intake cam guide
The camshaft also looks pretty worn..
PlainoH2
Aug 29, 2021 08:40 PM
tharber
Feb 23, 2021 01:01 PM
H2Miami
Dec 3, 2018 05:20 PM
register1987
Mar 13, 2017 11:00 AM
man-of-war
26
Aug 23, 2015 09:23 AM
