Engine light...
Old Mar 20, 2021 | 05:47 PM
  #21
wpage's Avatar
The stealerships are famos for fleasing unsuspecting unknowing folks.
Advise you to get up to speed on basics of vehicle ownership. Buyer beware etc.
Take a course at your local vocational school on basics of automotivs.
Old Mar 20, 2021 | 05:49 PM
  #22
Originally Posted by WillieW
Did you ever get this issue resolved? If so what was the problem and what was the fix and cost of the repair.
I have the same issue with my 2009 H2. Engine light is on and just yesterday the red engine low oil pressure light flash on but went back off it came on 2 or 3 time it always went off. I have No odd engine noise. Oil pressure gauge sits at Zero wife said the meter sometimes goes from 0 to 80 quickly and sometimes stopping midway, but mostly bouncing between the low 0 and High 80. We have never had engine light come before only 60K miles.
It happen just after an dealership oil change. Would be grateful for any suggestions or recommendations, Before taking it back to dealership.
Verify oil level, check oil filter, drain plug, and oil filler cap are secure with no leakage. Visually inspect the wiring around the oil pressure sensor connector. Check voltage @ oil pressure sensor to ensure it is within specified range. If all good replace the oil pressure sensor.
Old Mar 22, 2021 | 12:44 PM
  #23
Please do us a favor. Do NOT DIG UP OLD THREADS because you have a question. You dug up a dinosaur in the H3 section to ask a question about an H2? All H2 questions go in the H2 section.
READ: Old Threads/'Necro-Bumping'
Old Mar 23, 2021 | 04:48 AM
  #24
WillieW's Avatar
Default My apologies
I do apologize, and sorry for the frustration and confusion it has caused. I was only looking for help with my hummer experiencing the same two error codes and the older thread was the results return from my search. this was my first post, and the problem in the old post I referenced described my issues exactly. I did not realize I was in an H3 post, or understand how the code are different as it relates to my H2. All I knew was that my search returned a post that was the same codes and description of the symptoms I was having.
As I read the post, I never saw a thread on how he was able to fix the hummer. So, I was only asking whether the gentlemen had gotten a resolution as it was not in any of the threads. My hope was that the person who originally posted would answer or someone else who had the same issue and finally to inform myself so I could get my hummer fix and maybe better speak with the dealership to resolved my problem and not have the dealership feed me some because I was so uninformed, Again my apologies.
Many Thanks for educating me on what not to do in the forum.
bassackwards
Jul 20, 2020 09:48 AM
Mr_Fulano
Jul 15, 2012 03:05 PM
madmike
Jan 9, 2012 09:14 PM
Seattle98H1 Opentop
Jul 16, 2008 07:41 PM
jrippel
Nov 29, 2006 08:36 PM
