Efan Conversion/Jet Mass Air Sensor!!
Old Mar 8, 2013 | 12:20 PM
  #21
Originally Posted by Ron46
Hey doc, I have a question about the pcm efan, how does it work in water and mud? Do you have a cut off switch for it, or it works just fine for that. I am worried about off roading in the summer and going thru a water crossing or getting mud on/ in it. Also some people say that it doesn't cool as good, do you fee it does? thanks!
You need a manual on/off switch. So if you have to get into deep water you can shut it off to stop it from turning on while the fan blades and/or motor may be in the water....... then.... you have to remember to turn it back on.
I am taking that one step further, by doing a 3 position rocker, when in the center position the fan runs as normal controlled by the temp sensor (with 2008s & up that would be controlled by the PCM through the tuning patch), then the "on" position will manually turn on the fan, and the 3rd position will shut if "off".
Allterrainblue07
May 23, 2013 06:21 PM
Abo Sa3aD
20
Sep 11, 2011 11:30 PM
Luigi
Aug 28, 2010 05:30 PM
flexline
Jan 13, 2008 01:32 AM
flexline
Aug 18, 2007 01:03 AM
