DRL's + headlights simultaneously..?
Old Dec 9, 2009 | 06:29 PM
  #41
Broken Halo's Avatar
Talking
Originally Posted by HummBob
Step 1: get some 20g wire, a 200v 1amp diode (Radio shack PN: 276-1102)
Step 2: Install the diode inbetween a line of wire. Or better put, get two pieces or wire and wire on to each side of the diode. You can solder it or wrap the wire around the diode wire and tape it up with electrical tape (NOT RECOMMEND, you should solder it)
Step 3: Remove the Prk fuse 10amp and the drl fuse 10amp.
Step 4: lift the park relay and drl relay and place the wire/diode ends (exposed wire) into the specific slots in the relay. 86/85 respectivily. Make sure the little grey strip, the cathode side, is point towards the PRK RELAY 86. Also make sure the diodes wires arent exposed and not grounding on anything.
Step 5: Replace the relays in their specific slots. Make sure to line them up correctly; they got numbers next to the contact points on the bottom so its really easy no to mess this up.
Step 6: Replace the fuses.
Step 7: Enjoy!!
HummBob.....I want to switch my DRL's from my low beam driving lights, ('07 & '08 version), to the parking lights ('06 version). Reason is, I want to upgrade my headlight bulbs, and if I switch DRL's to the parking lights, my upgrades won't be on at all times, and thus, last longer. Do you know how to make the switch? thx
'08 Birch White Alpha
Old Dec 9, 2009 | 07:16 PM
  #42
Default Swap DRLs from low beam headlamps to parking lamps
Step 7: Enjoy!!
Old Dec 10, 2009 | 01:15 AM
  #43
pteam's Avatar
If you have a 08 Alpha h3, this mod is not for you, this is for h2's.
Old Feb 26, 2010 | 12:49 AM
  #44
blacksc's Avatar
Id like to do this mod, but my DRL's don't even work, i have put new LED bulbs and gone back to stock bulbs and nothing makes them work. Do i need to replace the DRL relay? Any ideas would be great.
Old Nov 1, 2010 | 02:41 PM
  #45
LOVEMYH2's Avatar
Guys,
How do you do this mod on a 2008 H2? My fuse box and relays are different. Don't see a DRL relay.
Old Nov 1, 2010 | 04:37 PM
  #46
luda81's Avatar
Did you check the fuse?
Old Nov 1, 2010 | 04:42 PM
  #47
luda81's Avatar
Originally Posted by pmalla5
yo man easier way than diode and stuff to get full function that you can use them during the day as drl's and together with ur headlights you connect then to the orange hazard lights ( boxes to the side of the headlight) this way if you would accidentaly blow a fuse you lose your drls adn hazard light on a small 15 amp fuse instead of losing your head lights which you could get a ticket plus the fuse for head lights is a speacial order or you have to buy them at hummer.
wat you do is take out the small fuse in your engion comparment bow marked for your drls not fog lamp that is a useless fuse.
then you cut your wires leading to your drl's reasonbly that you can connect some more wire without hassel of sticking your hands in that tight spot. after that you connecthe wire to your hazard light (the shrink wrap it or electrical tape and your good to go)
oh just tuck away the wire left behind from ur drls that was leading to them that you cut so if in the future you want to restore it its there and tape the fuse that you took out to the inside of your box.
__________________________________________________ _____
that was the way i did it and the way i trust it to work properly but you can also connect a diode between the hazard marker lights and the drls. if you do this during the day you can turn on your drls adn at night both will turn on, but to turn on during the day you flip the light switch up one to the picture of two lights opposite eachother.
but you do what you want i know this way works cause i did it plus i highly dont!!! recomend the diode to ur head lights in case you do something wrong and you blow that big fuse which u can get a ticket at night for having no lights till you replace thiat, this ur safe even if you blow a fuse cause its not ur head lights!!
this is how mine looks at night !!!
[IMG]local://upfiles/2599/CDE31F6DCE91494AAFA34C4D50499025.jpg[/IMG]
[IMG]local://upfiles/2599/473D18A5674945FEBA6FC8A45BA052BB.jpg[/IMG]
Hummbob way may be a hell of alot easier but this is probably the safest way in my opinion.
Old Nov 1, 2010 | 05:47 PM
  #48
LOVEMYH2's Avatar
Is there a DRL relay for the 2008 H2?
Old Nov 1, 2010 | 06:00 PM
  #49
luda81's Avatar
There should be.
Old Nov 1, 2010 | 08:55 PM
  #50
LOVEMYH2's Avatar
Guys here is a picture of the underhood fuse box of my 2008. No DRL relay that I see. The pictures of the other fusebox in this thread must be for a early model.
